0 Members and 25 Guests are viewing this topic.
light2011
@T-1000, @ STIVEP, @ WESLEY or  @....
1) You've told us that consumption of 10W from yours supply(on 18T/50T). On HV side, how power do you have?
2) I see in yours foto, on side with 150T, some caps(I think three...) 6800pf/3KV placed aprox. in the middle of the winding. Please can explain how many turns have between terminals of the caps? or how many turns remain between start - end of coil? or which is the position on coils(also nr. of turns)?
stivep
Guys I do not have yet empirical data,I'm playing with the device that is the same
-as in first  video of Caduceus with pickup coil
-as in Lithuania  Caduceus with pickup coil.
from point 11 in diagram you see Avramienko( Abramienko) fork - capacitor across- one spark gap at one leg-caduceus coil connected to  spark gap and other leg of fork,- Pickup coil with (3) ends,-
diode-capacitor across-spark gap  at one leg, and here is little complication as I just woke up  and yesterday I had no idea what I was doing at that point.
Something simple
I have to look at the device Two light bulbs connected sort of cleaver  way but not planed or desired,
I need the time to deliver.
I'm not doing this project in USA the same way as we did in Lithuania.
That means no rush
Once effect is reached next there is process of testing, and documenting of that particular step.
There is no chaotic and sloppy structure here but yes there was little chaos on the testing table
only because I did not build holders for the parts say.. spark gap had 20 of different forms and dimension. Capacitor homemade like book, was occupying a lot of room should be fixed vertically
or under the table.There is plenty of room for it there.
Wesley
wattsup
@ronotte
I change my diode, changed my HV caps at C2 and put 10 x 4700pF 3kv in series. I put the same cap set-up at C4. I then connected the HV ground back to earth ground and did not connect it to the Caduceus Coil. I am getting sparks at SG#1 and now I am getting sparks at SG#2 off the Caduceus Coil. But when I put a small light bulb load on the CC the spark goes out and the bulb in not  lit. BUT STILL, THIS IS GREAT and I will continue tonight. I have to go to the office now.
@stivep
Thanks for the vid. Good going. I think it would be really great if you grabbed and wide shot image from your last video and then put some identifications of the components you are using.
wattsup
PS: Regarding the series caps, do you think I put to many in series?
FreeEnergyInfo
stivep
Quote from: wattsup on January 19, 2012, 09:28:55 AM
@ronotte
I change my diode, changed my HV caps at C2 and put 10 x 4700pF 3kv in series. I put the same cap set-up at C4. I then connected the HV ground back to earth ground and did not connect it to the Caduceus Coil. I am getting sparks at SG#1 and now I am getting sparks at SG#2 off the Caduceus Coil. But when I put a small light bulb load on the CC the spark goes out and the bulb in now  lit. BUT STILL, THIS IS GREAT and I will continue tonight. I have to go to the office now.
@stivep
wattsup
My friend every build is different there is no steady fixed value of capacitors
I suggest to make switch and add capacitance by switching( adding more..)
Make sure that your spark plug does not have resistor build inside. Most of them do
The physics of photoconductive
spark gap switching:
http://alexandria.tue.nl/extra2/200611023.pdf
this should help.
Please read it carefully...
You do not have to add laser beam to it just concentrate on geometry of sparking device..and the distance.
analyze this one too. So what it looks like has nothing much in common... Just think and give others helping hand
http://hallaweb.jlab.org/publications/Technotes/files/1998/98-049.pdf
The NMR system of the Hall A polarized Helium 3 target
Page 39 overal picture of structure of 90 degrees coils movable axially
Page 40 coil orientation Top view
Page 41 Figure 3: this chart shows you the specfi cations of : the large Helholtz coils (axis 1), the
smaller Helmholtz coils (axis 2) and the RF coils (axis 3), given by the Walker Scienti c
Company.
Question: axial - movement of coils :
How it affects electron beam?
Wesley
