0 Members and 518 Guests are viewing this topic.
ronotte
@Alena,
Yes, I am sure, it is a long time I understood that: it is a clever way to 'close the circuit' & introduce positive feeback'. So, the TBC   Caduceus   pickup coil is to be considered like a whole circuit containing a positive feedback loop inside. The feedback amount is dependent on several variables so it is difficult to generalize it.
The concept applied by STAAAR team is simply, like in many old radio receivers, to feed back on the input a part of the output using capacitive or inductive way: here for sake of simplicity this 'part of the output' has been calibrated by designing a proper interwinding capacitance (140-170pf). The operation must be fine tuned in order to have the SG firing happening at the right time in order to have the next pulses charging more and more the stray cap so giving the famous trumpet showing a quadratic rise (concavity, not linearity...as it should be a divergent process). The additional secondary (named SFC by wattsup) has been found useful by STAAAR team to...enhance the feedback amount...?
As the positive feeback effect should be that to increase the trumpet amplitude... till auto-oscillation...I've already tested a similar approach by sliding a coaxial 10t coil over the pickup coil and feeding back the captured emf in series with the input SG#1 (much like Tesla suggested in one of his pat): nothing happen.
Heem...now I have an idea to follow the team approach and, while still using the kacher as source, connect the pickup coil Center Tap in series with the kacher's magnifier coil: this should duplicate the 'additional TBC secondary' on STAAAR team ver#2 schematic.
Roberto
@aether22,
I concord, the tank circuit does provide for resonation effect (it is easy to see it while working with low voltages). It is interesting also to consider that Caduceus + tank cap (1nF) resonates itself nsturally at more than 20MHz which is the limit of my lab oscillator. My GDP(Grid Dip Meter) showed  that CC alone has little resonance in 100-400MHz (may be it resonates better at much higher freqs) range...so why is effective at such low frequencies? (in my case source is at 2-3MHz) and SG firing 3-5KHz ?
Roberto
aether22
Ok, one thing I don't get, how come the Caduceus is being considered non-inductive?
Clearly it is only a few turns and they are spaced, but they aren't bucking or cancelling. (as caduceus coils can be wound)
And Ronotte, your bifilar pancake primary, if connected as Tesla had, would the fields of the 2 halves not be reinforcing?
That the caduceus, and your coil bifilar resonate at a frequency they aren't resonant at makes me wonder, what if it isn't really an inductor but just an unusual capacitor plate?
This could be tested by taking a wire and shorting out more, less or all of the 'primary' turns. I hope that isn't it.
Second test, that happens if the impedance of the primary is increased by putting an inductor in series to bring the resonant frequency down to match.
I don't blame you if you don't try these tests, but that it isn't resonant on the frequency it is oscillating on is very unusual.
I see how they are always avoiding resonance.
Addition
A tank circuit 'oscillating'  at a frequency other than it's resonant frequency (if that is what is happening) must mean that it is being impressed very powerfully by an EMF, so where is this EMF coming from? The pickup coils or the flyback/kacher?
Also I understand the value of this tank cap is sensitive, but if it isn't tuning into the actual electromagnetic resonance of the frequency it is picking up, then what is it tuning to? Something aetheric/radionic?
ronotte
@aether22,
you are posing same questions I asked myself, hence is time I show the caduceus + pickup coilspectrum (in the non powered & powered condition) in order to see exactly what's happening ;D
I have the possibility of using my big Tektronix  color 6 traces with built in spectrum with amplitude & phase capability: I only hope it is still operating. So I hope to fully characterize the coil set.
Roberto
aidas
FreeEnergyInfo
