0 Members and 137 Guests are viewing this topic.
aether22
If you create a tank circuit that has a natural resonant frequency much higher than the frequency you have imposed on it, you are stopping the current dead.
So one possibility is that there is a very high electromagnetic field that is inducing the CC , but the current is stopped dead by the capacitor. (Since it is out of resonance, none of the energy is sloshing back and forth, each tiny peak of the trumpet waveform is driven directly, not being added to!)
I was wondering if this was somehow helpful, but I can't see how it is, clearly to induce 1kv or so per turn at 15khz the field intensity would have to be quite strong indeed and not easily killed by a bit of current.
This EMF could be pulled in from the flyback/kacher, actually coming from the pickup coil (what if the pickup coil is actually creating this frequency?), and possibly supplemented aetherically.
Otherwise what if the AV plug is doing something, what if rather than an electromagnetic field it is an electromotive force (Not an EMF but an EMF, acronyms suck).
If so it is likely related to the capacitance between the CC and the PC, especially when the latter sometimes is connected back to the circuit.
If the capacitance between the CC and the PC was increased by putting a cap in parallel, could C3 be increased?
Essentially though, if there is a current running through this tank circuit then there is a lot of energy and probably an intense electromagnetic field around the coil.
If it is some other mode of oscillation, then there might be less energy potential.
So maybe the real question is what a test pickup coil shows?
A simple coil connected to a scope (or even a BR and a volt meter) should tell us what is happening in that circuit.
Double the number of turns should double the voltage reading if it is transformer action, some orientations shouldn't do anything or very much.
Tests:
Short turns of CC (or ronotte's Spiral) (primary) to see if it's minimal inductive properties are required
Put an inductor in series with the CC to increase the impedance of the 'tank circuit'.
Increase the CC to Pickup Coil capacitance by putting a cap in parallel, then increasing C3 to match.*
Make an air core test coil and see how the inductive ramp waveform (assuming it can be read this way) behaves, does it follow transformer action with turns and voltage and orientation?
Put the SG in parallel with C2, if each bit of the sinus wave is induced newly rather than being stored then the sparkgap pulsing through the CC can't be contributing much, so test it without firing through the coil.
*Especially with the feedback connection from the output to the flyback/kacher.
I am tempted to try this, but the more I find out about the circuit the less I know about it.
aether22
I just made a post and it was lost, but here is the gist of it...
Romero has made the trumpet waveform in this case with the spark gap in parallel:
http://www.youtube.com/watch?v=8-ba0aJnrYo&feature=related
This removes and idea that the impulse must be discharged through the coil to give it a bang to induce this waveform.
And here he shows that it doesn't require an AV plug either:
http://www.youtube.com/watch?v=YEop6jxH8uU&feature=related
Just one diode will do.
This is making me wonder if if could be explained like this, but I hope this isn't it and Ronotte results of getting a higher voltage out than in suggest that this following though is either incorrect or only part of the story...
The power is applied to the circuit, it sees the capacitor is just waiting to be charged.
The circuit is low power and so the voltage is pulled down by the capacitor.
Each cycle the capacitor gets progressively more charged and with it the voltage (not current) measured gets higher and higher as the capacitor is less able to pull down the voltage.
What is being seen then according to this theory is merely the inability for a featherweight powersupply to provide the rated voltage when the load draws too much current.
Note I have not tested this, I'm not sure it makes sense 100% and I don't think it explains everything seen.
Of course even if this explanation for the trumpet are correct, it might still be a great way to cause interaction with the aether.
Update: I built the circuit in his second video (sans transformers) in that java circuit simulation and it gave me a one sided trumpet.
If the scope was set on AC it would probably look more like a regular trumpet.
So it IS possible to create a trumpet with a slightly different circuit where an AC signal charges a cap through a diode then fires through a sparkgap without any energy gain.
I don't believe this rules the trumpet out, but it isn't a definitive indication of anything unusual or of Free Energy.
duff
@jbigness5
Thanks for the explanation of the diagrams presented related to the Tesla Pierce Arrow.
It's always good the know the source.
Ghazanfar_Ali
Ok guys I did it. A self running resonant circuit. Input is around 10mA with 5 V to drive the 555 timer circuit. Rest the magic is done by initially charged capacitor. the load is connected after switching on the timer circuit generating pulses. I connected a 50W tungsten filament bulb and it glowed almost to its full brightness. I tested the circuit with 9V battery just used for driving 555 Timer circuit and it made the bulb glow for 5 days. Battery is rechargeable one with 1000mAH. Output is almost the same as around 45W. I will upload the video soon on youtube.
U can replicate it. A very simple one. Use an LRC meter to design the L1. I used a ready made based on ferrite toroid.
Best of Luck
God bless U All.
Ghazanfar_Ali
This one has also been tested with almost similar results. The oscillation starts without any delay as compared to previous one. i used 7805 for 9v to 5v DC conversion. Here is the variant. A group tried to discourage me coz they never want such simple things to be made by everyone just to have a hold on the subject. But let me tell u Now my next variant is to drive the same circuit using voltage stored in the capacitor. I am using Teslas radiant antenna (The black hole Antenna) to get collect energy from atmosphere and drive the same circuit. It's just the ingenuity of mind. Use your precious brain and we all can do it.
Credit goes to my team member Shahzeb Hussain  who recently won Pakistan Intel Prize for young Innovators.
