0 Members and 447 Guests are viewing this topic.
forest
Quote from: baroutologos on February 01, 2012, 03:22:30 PM
I think, he subtly implied, that the initially charged capacitor is not obvious discharged and lasted a week, rather than oscillates the current back and forth towards the LC component (which in turn kicks it back by some means), somehow skyrocketing the voltage (when mosfets closed),  while a tiny current pass through the inc. lamp thus (in theory) producing power.
Bear in mind stefan, hypothetically such a OU system as depicted has its amp meters showing AC high frequency current and of weird wave shapes rather than DC. If you just sum all currents you would see the current that oscillates back and forth through MOSFETs ( stage 1 through drain, stage 2 through diode -reversed-) and bulb is equal to initial capacitor's thus the law of charge preservation is not violated.
What remains to be seen is the violation of law of Energy In = out... interesting and amusing go on...
I think energy is being created in two cases: first when there is parametric resonance (trumped exponential waveform?), second when resonant tank circuit is oscillating without looses,without damping. Time will show if it is creation through tapping external source of energy  using open circuit or we just have wrong comprehension of energy usage !  For example light can be produced very efficiently using phosphorescence effect and resonant tank circuit as opposed to incandescent filament.
FreeEnergyInfo
NEW KAPANADZE VIDEO ....
www.youtube.com/watch?v=ADr1lT9MeIE
www.freeenergylt.narod2.ru/kapanadze_6/
FREE ENERGY = FREE INFO !!!!!
hartiberlin
I made a backup copy of this new release video from 2004 here:
http://www.youtube.com/watch?v=B4X5zy0piSg
This seems to be an older video from 2004 where the single parts still can be seen quite well.
I am spotting a transformer behind the coil with a graetz fullwave  rectifier bridge and 2 black chokes.
What is inside this round box with the switch on the top is still a secret to me...
Maybe some additional coils ?
Interesting is that he has a sparkgap running between the 5 winding secondary output coil and the primary coil of the Tesla coil type...
Hmm...
stivep
Quoteauthor=skaarj link=topic=7679.msg311260#msg311260 date=1328111819
Look... it's LIGHT!!!
(later edit: a 40 Watts bulb full light, f*ck EU - stupid laws, no more 100W and 200W bulbs allowed for sale, they do not want any of us to experiment anything)
QuoteNow, if you look more carefully, you will see that the bulb is connected to the 220V socket in the wall, and not to the yoke. Because I did not manage to repeat your experiment, but I believe in you and your work and I do not want to give up.
I would like to make this happen for real, and not for a bad joke.
I respect that
QuoteSo Mr. Wesley, you have ignored my posts on this topic and I understand you are very busy, but now that I got your attention, please tell me - the secondary winding (150 turns, two wires together) - is it a CADUCEUS or a normal double wire winding?
No I never  Ignore anyone.
I have got trapped between me being able to provide communication with others and me being able to work
There is not enough 24H  day to respond to everyone.
Windings are
15
50
150 bifilar one end of double wire connected to the begening of the second one. The two ends remaining is the output to light bulb.
But.
Never count on that.
Every  ferrite from yoke is different
Everyone has different characteristic.
Frequency response might be over 2MHz at that point problem is limitation of generators.
With the time ferrite might change its own ferroresonant response.
I'm not a guru.
I'm regular human being.Never better than you. Everyone has its own value.
Advice:
I have purchased my generators  from Ebay.
For the price of one  generator used in first experiment one can get 2 generators
HP or any other .
example:
http://www.ebay.com/itm/250770321874?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648#ht_1962wt_923
New one could cost you $1200- $1500
One good that comes from you collecting equipment is knowledge and tools to progress.
When the time comes You will be in the army of first who will benefit on your education
That day might be very close.
That is what I did.
I have start 2 years ago digging  for equipment.
Ebay is so educational.
I have more that 10 generators  and every one has different unique futures.
YOU WILL FIND THAT YOU NEED 1 OSCILLOSCOPE BUT ARMY OF GENERATORS.
Some of them are 40 years old and still better than new one for given application .
One of good things that you have  in that small generator is ability to  carve signal to desired  shape.
QuoteI have all the equipment: 3 signals generators and the spectrum analyzer -  1xPCSU1000 and 3xPCGU1000. It has not been easy for me to buy them. I also have 4 yokes, as following:
first from left - from a Stassfurt T205 made around 1965 in germany;
second from left - from a Temp 7M
third (down side of picture) - from a Rubin 102
4th (right side) with windings - from some 21" video monitor.
Do you think for me it was easy to buy my equipment?
I'm not rich.
But I put every money I could  into that and I found one  very good answer.
I HAVE LEARN HOW TO BUY
I HAVE LEARN  HOW TO BARGAIN FOR THE BEST PRICE AND HOW TO CHECK IF THERE IS NO CHEAPER ONE.
I FOUND THE SCAM ON EBAY... never buy( unless you have no choice) device that has 2-20 bids on it and there is still 1 or 5 days left to the end of auction The guy is  ("most likely") :) using multiple accounts to fool you creating artificial traffic of non existing bidders
Click on number of bids (left button) and it will  get you to checkup. If you see 3-100% activity of bider to  this seller ("most likely") :)  it is a scam.
QuoteI wrote the drivers and a program using Unix BSD, a little of C/C++ and many nights with no sleep,  to auto-tune two of the PCGU1000 to the frequencies where the voltage at the "two wire secondary coil" will be maximum, with the light connected. All possible combinations of amplitudes, wave forms, pre-defined and also from libraries, also for square the duty cycle was between 1% and 99%. All measured data was recorded in MySQL databases. The test was performed like this:
1. it took me 1 week (7 days) on the Rubin-102 yoke and 1 week on the 21" monitor yoke, with signals sent to the yokes via Field Effect Transistors. (later edit:) Electricity for transistors was +12V from a PC ATX power supply.
2. 1 week on the Rubin-102 and 1 week on the 21" yokes with DIRECT connection to the yokes.
Data was stored in around 300 MBytes of compressed MySQL database.
After 4 weeks I had all the data (frequency, wave form, amplitude).
Many combinations made a little light, but the most strong I managed to make on the Rubin-102 coil at 450Hz base frequency (50 turn coil) and at around 3700kHz on the modulating coil (15 turn) by using Field Effect Transistors, both signals SQUARE, both 50% duty cycles.
No sparks yet, I have to build some additional circuits, I am afraid to burn the generators - US$1500 is a lot of money for me. I want to repeat the 150 watt experiment, that one where you still did not discover the need for spark. Please help.
All of the information is in this forum or energetic forum. I suggest to myself that if I was to start from nothing I would fallow  instruction published  step by step and try to see what was pointed  there.
I can not advice you  to do anything  legally.
My legal statement must be never play with it.
You should understand why.. world is full of sharks.
That was us who spend money dedicated  to our families to give  something to others.
I have seen on project in Lithuania that when we introduced spark that we have had immediate results.
Aidas damaged his generator doing that.
There is one more mysterious moment.. unexplained headache. That one was reported for the first time by Aidas. Than in Lithuania All of 5 people experienced the same.
One of very good generators that I have  is Wavetek 166 and Wavetek 193
Each of them has its own disadvantages.
There are  analog generators and there is no stable level voltage when you sweep.
Generator HP 811A has stable voltage while sweeping. But it does not have ability to create  ramp impulse with horizontal remaining part of square at the bottom without bias.
Every time I have purchased new device It was a pain. With the time I found that equipment I have acquired is easy to sale for much more that I have paid for it. ( only previously used one)
The longer I have it  the better I understand  how to use it.
Once you get into this you will find that many things you have had problem with  is easy with the time.
Caduceus concept is  different from  yoke.
But.
even if there are many ways to Washington there is only one mechanism that is  responsible for desired phenomena.
Major difference is that in yoke  we used NMR   as explanation
In caduceus we used spark speed of transition as explanation.
QuoteLater edit - sorry, I do not want many posts with little things:  added one more picture with flyback transformers. From left:  Stassfurt T205 transformer, second: the old and strong TBC-110L (a new, unused one, some цигaHcKи tried to destroy it long time ago) and at right side - two Rubin-102 TBC-b.NIO.449001 from Rubin-102. I will have to try all of them.
Heaving Flyback is important. It is not easy  item to get. Specially one without diode  immersed in plastic.
I have spend a lot of money for it.
Old TV ( very old) is the answer.
Just pick them from the street.
UNDERSTAND PLEASE .. NOTHING YOU DID IS WASTE OF MONEY..
It will payoff with the big profit when the day comes.
Wesley
hartiberlin
Can somebody who understand this language please post a summary about what this guy says:
http://www.youtube.com/watch?v=PX8_8QkbBKQ
Many thanks.
Regads, Stefan.
