0 Members and 105 Guests are viewing this topic.
stivep
PART1 NYW group Aidas Arunas  Wesley
Quote from: ronotte on February 01, 2012, 12:12:15 PM
@wattsup,
thank you a lot for your considerations, while studying what written, I urge you to see last 'schematic ver.2' released by Wesley: THERE IS NO ADDITIONAL SECONDARY. THE ONLY ONE SECONDARY IS REFERRED TO GND; no connection either between the TBC's secondary and pickup coil center tap. I do not know the why of that. Wesley, please clarify that point :)
Thanks
Roberto
Note: I have tried to feed back in several ways the center tap connection to the kacher in order to try to establish a positive reaction so possibly extending the diverging trumpet...up to now without success: the circuit quit or changes only a little his operatimg point.
first two pictures represent  similarities between all of TK spark gap used  in any of his presentations significant is
FLAT SURFACE OF SPARK CONTACTS.
I have  noticed that I have good response with flat surfaces of spark gap
Picture #3 and #4 counted from the top down
Schematic done on mosfets
notice TK DID NOT USED MOSFETS IN HIS VIDEO FROM 2004
You can make  the same schematic with  regular FET transistors.
That what Wesley Aidas and Arunas think is inside epoxy cylinder in the middle
From the top of epoxy cylinder  you have flat copper  disk part of capacitor.
Please disregard   part of text  below  is not finished as of yet
I have no time to  make connection between  Lithuania experiment ( self looping) and TK 2004
When I come back I  will try to make proper assumption.
Is Lithuania experiment concept with coil capacitor and additional feed for samozapitka self looping   concept of Aidas.
"Drive" box  is connected to coil (conceptional) -  how the coil of samozapitka (self looping) connection  should look like.
gyulasun
Quote from: Ghazanfar_Ali on February 01, 2012, 03:16:24 AM
This one has also been tested with almost similar results. The oscillation starts without any delay as compared to previous one. i used 7805 for 9v to 5v DC conversion. Here is the variant. A group tried to discourage me coz they never want such simple things to be made by everyone just to have a hold on the subject. But let me tell u Now my next variant is to drive the same circuit using voltage stored in the capacitor. I am using Teslas radiant antenna (The black hole Antenna) to get collect energy from atmosphere and drive the same circuit. It's just the ingenuity of mind. Use your precious brain and we all can do it.
Credit goes to my team member Shahzeb Hussain  who recently won Pakistan Intel Prize for young Innovators.
Hello Ali,
Here is a link, reporting on your team member success and I would like to read more details if you or he could care to provide on creating electrical energy from the Earth's magnetic field:
http://www.columnpk.com/shahzaib-hussain-invents-worlds-cheapest-way-to-produce-electricity-from-magnetic-field/   What you mention above on collecting atmospheric energy to feed your circuit,  is it the same principle what your team member used?
Regarding your present circuit, can you provide a picture on the working setup at least till you can make a video? You use a ferrit toroid core, could you identify the material type or if you do not know it,  perhaps you tell the number of turns for getting 337uH or 345uH inductance, together with the OD, ID (outside and inside diameters) and the height of the toroidal core?
Thanks,  Gyula
energia9
unforntunately, energy extraction has not been invented by 1 person,  it has been stumbled upon by thousands of people,  it comes in many forms and many ways, it can not be patented and can never ever be sold in the monetary system.
monetary system is based on profit from energy, if monetary system fails, humans can be at the edge of a disaster or a great change
Ascension.
we decide which one
WELL DONE EVERYONE.
Ghazanfar_Ali
@Broli
Well u cannot say that resonant freq calculated by the formula is also valid for square pulses. Here since it is at 50% duty cycle it is 2 time of 1KHz. If u give 2 KHz Sinusoidal it is having the same effect if u give 2KHz/2 = 1KHz pulse to the same LC cct with 50% duty Cycle. But in this case u will get higher kick offs. I practically checked that using my DDS 3x25 function gens.
As far as your java based cct sim is concerned. Try to check it again using following steps.
Place an on off  switch just before the load of 300Ohms.
Keep the load disconnected from rest of the cct by keep that switch off.
Charge the 4700uF capacitor to 50VDC.
power on the pulse generator and after a few seconds connect the load to rest of the circuit.
This is the only way to trap the energy and get oscillation.
Try this and plz let me know..
Best of Luck
Charge the capacitor completely to 50V DC.
Ghazanfar_Ali
@Gyulasun
Dear, I cannot give u detail pertaining to Hussain's OU device which works on the principle of SM's TPU. The reason is that we are still trying to optimize it and b4 doing so I cannot make a confusion for all of you. As far as my self running device is concerned I will try to load the video asap as i m very much busy in helping my better half for her final exams.
Plz dont mind.
Best Regards
Ghazanfar
