0 Members and 216 Guests are viewing this topic.
Quote from: Ghazanfar_Ali on February 02, 2012, 03:52:23 PM
@Broli
Ok here is another optimization. I simply increased the amplitude of pulsed DC from (0-5V) to (0-10V). And now I am placing a 10Ohms load which is almost equivalent to a heating element. Now The power output is around 800W.
And it did not affect the oscillation.
U can use capacitors in parallel and series combination to get the desired value.
In this setup the initial charge capacitor has a capacitance of 4700F!!! Did you notice that?
Meanwhile I installed multisim 11.0 and tried to copy your previous setup. The voltage seems to dampen fast in my setup so I don't know what the difference is. Could you perhaps take a look at it and point out what has to be changed?
stivep
Please read this text
QuoteWhat they say in this video is of no consequence. There, they do not reveal how the device works.[/font]Kapanadze generator is a modification of CZ 284 333, the three coil version. The modification consists of using pulsed HF generation (spark)  rather than the continuous wave as described in the patent. The spark is phase synchronized with the magnetic field modulation sine-wave (~50 Hz). The principle of operation is best seen in the pictures from Georgia, published by Wesley. Bare in mind that the fuel in this generator may be either Fe or Cu in the form of foil. I think, Kapanadze will reveal it sooner rather than later. Michel Meyer revealed it first in the Science et Vie article in March 1976.You can assume the same, or very similar, for  Steven Mark devices.
Wesley
PS:
I would like  you to revisit series of videos of mine from Georgia.
coaxial cable was used there
Spark was replaced by  HV module from  gas heating boiler
That is the best way to get to bottom of this secret.
cosmoLV
Quote from: stivep on February 02, 2012, 08:56:17 PM
Wesley
PS:
coaxial cable reveals nothing without understanding what you are doing.
â€" in this video it is used as inductor coil (it has a needed area for that) at that moment they don't have sufficient thickness cable. that's all.  /sorry for my poor English/
P.S. you have rights to not believe me, but respect what I'm saying... i don't want to mess up with your work, but â€" listen what I'm saying!
At least, for High Voltage are used Trigger schematics (Gas ignition is great choice for that) but you can make simple one â€" and it works in same way! Learn Tesla patents â€" everything is there, but peoples want to build a space ship. :)
/The secret is not in power, but controlling electric currents in magnetic field/
Keep your chakras opened :)
Mannix
Quote from: broli on February 02, 2012, 07:53:37 PM
"Unexpected end of archive" in the zip file .?? any body else?
Ghazanfar_Ali
@broli
Sorry Dear I am unable to unzip it. I think the zip file u loaded is corrupt. if u kindly upload it again so that i can go through it, why your cct is behaving differently?
Ghazanfar Ali
