0 Members and 188 Guests are viewing this topic.
Ghazanfar_Ali
@Broli
Plz try this and let me know. I think as I mentioned earlier when I started these posts I gave some initial parameters. u have to set the rise and fall time of the pulse generator either 10ns or its much better to keep it 500ns. I dont know why it damps on rest of the values. May be its the exact resonant freq. I am attaching my sim file of NI Multisim. Check the simulation and let me know.
Thanks and Best of luck.
Mannix
duff
Quote from: Ghazanfar_Ali on February 03, 2012, 12:52:36 AM
@Broli
Ali,
I downloaded your multisim file and it runs OK here.
Linux system / running Multisim 11 .0 under VirtualBox
I've got transistors, capacitors on there way and working on winding inductor now.
Looking forward to pics or video of your setup.
Thanks for sharing!
@Broli
From your file I managed to make my setup behave the same. What seemed to be important were the simulation settings:
Maximum Time step: 0.0001s
Relative Error Tolerance: 0.01
Truncation error overestimation factor: 7
Those are the main values that need to be set in order to get the effect. Changing any of those will result in the voltage damping.
I hope the attached zip is not corrupt this time.
Jack Noskills
Good stuff Ali!
Could you try what happens with higher pulses, for example 9 volts, 18 volts, 27 volts, multiples of 9 for nine volt battery started device. To see how the output power scales up.
Have you managed to do loopback yet ? When you do, Stefan here has some money stashed for you. Also go and get your goldmedals from Doc: http://www.overunity.com/index.php?topic=11661.0
You are using ferrite toroid. Is it possible to use nanoperm, permeability is 80000. I am asking because I got some of those laying around, small ones, 63 mm outer diameter, 23 mm high, 13 mm thick.
Did you start new thread already ? Did not yet see it in front page.
