0 Members and 88 Guests are viewing this topic.
ronotte
@stivep,
thanks so much for clarifying the point. I encourage you to advance/complete your research and try as I think you are doing, alternative exciting ways. For example I'm trying to take advantage by using 1/4 wave of the well known (by OM) RG-8...in fact my kacher is growing up incorporating funny features never seen up to now. I  am following also the idea to incorporate everything inside kacher itself...as the TK device is BASED on a Kacher ;)
Roberto
bolt
Quote from: poynt99 on February 03, 2012, 09:38:09 AM
OK, thanks gents.
I'm not that familiar with Multisim, but all simulators are much alike. I'll sim it up in PSpice and post my results.
I can assure you that there is some misunderstanding regarding what Ali is measuring, or how he is making the measurement. At the very least, something is not being accounted for.
I think we all understand that it is impossible to achieve an OU result with SPICE.
Regards,
.99
TRUE!  A  SIM can only do math based upon known principles.  Cap loops with zero resistance etc and expanding VARS via lumped inductance (OU trumpet signatures) normally create a Division by ZERO error and the program crashes. What do you expect from a math program not expecting > 1 or over unity? LOL
Same thing happens in Falsted.  SIMS do have there place though and are useful for deriving ideal driver circuits.
JJUK
Thanks 27Bubba. Unfortunately that's not the problem. I've already installed the 30 day trial of Multisim. The ZIP files appear corrupt when I try to open them having downloaded them from Overunity.com. All I get when I try to open them is the message that I provided in the screenshot previously. Just can't get at the zipped files. Perhaps someone could share them over SkyDrive or similar?
JJUK
cosmoLV
Quote from: stivep on February 03, 2012, 09:50:11 AM
That is the point
You not reading carefully enough
You not watching carefully enough
You not analyzing carefully enough
It is not me who is doing something it is TK  helper who assembled this device to present it to me.
http://www.youtube.com/watch?v=_YPVwfnvqw0
http://www.youtube.com/watch?v=IAPe3DiYt2o
http://www.youtube.com/watch?v=fBgDwG2ZLkM this one start from 09:15
Conclusion:
Coaxial cable was utilized in video 2004 [size=78%]http://www.youtube.com/watch?v=B4X5zy0piSg[/size]
and in TK show to me.
SHVGS ( Stupid High  Voltage Generating System) from gas operated heating boiler
generates
-burst of impulses for few seconds than stops
-sensor wire  fins that spark is no longer there and sends burst again
-when flame( plasma) is present sensor senses current(? voltage)
and do not send request to electronic circuitry  for next burst
For Tariel the importance is  presence of spark.
In presentation for me personally Tariel device did not have spark gap
that means that spark gap is only HV DC chopper
that means that most likely, spark gap is not important if other means could replace spark.
I was not sure in series of my videos  how that spark creating device was connected to coaxial cable.
But I know I think right now how SHGS works.
Coaxial cable has inner conductor and shield
All purpose is to have HV impulse present in coax but not in inner wire as shield would normally shield  the EMF. But what about electrostatics hm?
You have 3 wires form withe box
You have 2 ends of coax inner conductor
You have 2 ends of coax shield
There is nothing in addition connected to it
so connect it. that mechanism I described here is sustain.
There are many of you who sweep market from white boxes.($7-$15)
Connect coaxial cable and try it making sure that burst is sustained and supported by sensor!!
One part of puzzle will be  clear. for both instances
- TK from presentation to me
-TK from 2004
Wesley
Device what showed for you in Geargia â€" outer coil of coaxial cable - is used as conductor (middle wire are not connected) Why? i already say it. â€" this is first thing!
About Green Box
â€" Peoples who are there when they filmed, can confirm 100% that there are no coaxial cables.
4 years ago (when you even don't know about Tariel) i talked with video operator who filmed a green Box video (and others who be there) â€" he worked at that time in Geaorgia Television. Don't forget that i also working in TV and have more  contacts in Georgia than you can imagine â€" and i connot listen your lies about what is in Tariel devices!!!
First â€" this is stupid!
And second - respect poeples around you and respect Tariel's work.
About Transparent box:
There also are no coaxial cables in any case! There are three coils.
1) magnetise coil / horizontal /.
2) HV coil / vertical in front /.
3) inductor / vertical on back /
And Hidden schematics block at end bottom of the box.
(the schematics who are you see there - are only to hide some parts!
About gas ignition:
Who say you that there are no custom schematics inside ignition box? You think Tariel is stupid and show for everybody secrets?
no it is not what you think!
Time goes and you like it or not, but you must agree with me! Sooner or later you do - because you don't have a choice.
P.S. your attitude is very aggressive for now, be friendly and maybe someday, somebody reveal some secrets for you! actually as you remember i sent you couple Pm's about work of the device, but you even want to listen - this is your choice.
... But stop fool peoples!!!
(Spark Gap are not play power role in device, it is used to make abalance at "0" point between Live and Ground) conductor are conneced in 3 points coil are divided in 1/4 â€" one of this point are spark gap.
Keep your chakras opened :)
cosmoLV
Quote from: nightwind on February 03, 2012, 10:21:10 AM
@Stivep
The biggest thing missing in all of TK's videos is his lab/shop?  I've seen no fancy instruments (just an amprobe).  When you were visiting him,  did you see his shop or where he did his work at?  Thanks
There are no much in his lab, Capacitors old TVs without HV transformers, and other old soviet parts and etc... But this are some 4, 5 years ago.
what has Tariel say at that time was that device is very simple.
..and at that time â€" in 2003 when Green box was filmed in his lab are no ossciloscopes (only old soviel frequency reader) thats all...
