0 Members and 82 Guests are viewing this topic.
stivep
Quote from: wattsup on February 03, 2012, 06:43:28 PM
In the TK 2004 video, I think the reason they shut off the device after only a brief moment is because the spark gap is soldered onto a copper wire and if it heats up to much, the solder will melt and the gap will fall. This has happened to me when I first started playing around with the spark thingies.
@stivep
Talking about spark gaps, I just received a spark gap I ordered off of eBay (what else is new - lol). The seller has another one here....
http://www.ebay.com/itm/GDV2-Ericsson-Tel-England-Spark-Gap-Discharge-Tube-Rare-/200707486445?pt=Vintage_Electronics_R2&hash=item2ebb1932ed
I have a pdf of it here - just click on the GD2V.pdf file
http://purco.qc.ca/ftp/Tariel-Kapanadze/Wessley-WNY-Group/spark-gaps/
The gap has a female thread on one end so no problem there. But on the other side all it has is a brass like stem and I don't know what to do with it. Have you had this kind before and what do you use to secure your wire onto it? Geez, just realized it looks just like the one you just posted.
The other thing is about those scr's in series that you posted..... Man I'd hate to the the last SCR in line. lol
wattsup
Thank you my friend wow that is something :) Thanks for PDF
Mannix
Quote from: poynt99 on February 03, 2012, 07:49:25 PM
Just a quick one for those interested in the sim; The oscillation holds for about 20ms, then falls off. This with a 100 Ohm load. So unless someone has a suggestion to get this tricky circuit to hold its oscillation, I won't be able to get a good power measurement.
.99
What simulator did you use? Multisim shows good oscillation and accurate average power (you can even rectify it). However if you replace the signal source with function generator things are different .
It may be a sim error of course but Ali said that his circuit worked on the bench. Please use multisim and see the same results as your  reference point.
cosmoLV
Just finished making a pcb layout for quality 50Hz or 60Hz modified sinewave AC generator for inverter
it is based on one PIC programmable memory chip...
i attach images and PDF of PCB layout â€" who want's can make it!
Two things:
1.) you need to programm PIC with pic programmer
2.) Center taped transformer 10v - 0 - 10v output 220v or 110v
/ just forgot, i not label the mosfets STP55NF06L These are special logic power mosfets that require just 5v to switch on fully.
They also have a very low   0.014Ω Source to Drain resistance when on, which means they can switch high currents without wasting power as heat!/
A. This is PCB for etching: http://failiem.lv/down.php?i=mwqeoom&n=Inverter_PCB.pdf
B. HEX code for 50Hz and HEX for 60Hz: http://failiem.lv/down.php?i=hpnulzg&n=50-60_Hz_HEX.zip
Keep your chakras opened :)
cosmoLV
Quote from: stivep on February 03, 2012, 05:38:00 PM
Dear friend
Let's assume that you  100% right
Lets assume that you are aggressive not me
Lets assume that  I  and you we both do not know  TK secret
What different does it make that you will shut at me more?
NONE....
You will be at your home and I will be at mine.
One thing I do not understand about you....
What is that you want to  prove?
Where is  you want to go with all of this?
Do you know the secret and others not// if yes say it or say that you do not want to say it.
At the end it would be not important after all.
Nobody will remember  names of that great army of voluntaries
PS:  just say what is right approach... enlight people that's all..
*I prove â€" nothing ;)
just relax, difference between you and i is that i know how device are working.
you don't understand one thing: "that i like to help" ...but you don't accept this! :)
*Improtance? No!
This is not important who give schematics, there are no heroes, winners or losers â€" this is question of human kind.
By the way, this is maybe not story about you and many out there, this is story about all together â€" you need to know one thing!
You konnot change the world or change the rules of our goverments. With this device â€" YES you can! Free Energy is only one side of it, other side is the most powerful weapon in human history after Nucliar Power! By the way, nuclear power sits far back compare to this (Free Energy) principle.
Why i not release schematics? this is my conviction - that you need to make it yourself, i only want to make a little push...
Think...
P.S. I know that many has funny time to search this out, but this is not a game when you find the answer and see what kind of things and effects can be reached out of it. Then this is not a game â€" This is not a toy and never will be.
It generate its own magnetic field which is not depend of earths fields, without earth Grounding device produce too mutch power (but this is different story which are not related to Free Energy, there are more things not only FreeEnergy...
But all what can i say, that this secret not long stays in secret â€" we don't have choice.
duff
Quote from: Ghazanfar_Ali on February 03, 2012, 05:32:20 PM
@ All
Thanks for your comments. I know you all have some queries. First of all the schematic in which I got 800W is still under my observation coz my device sometimes gives 800 W just after powering on and connecting the load but sometimes it just stops giving output. The previous one with 42W is stable and works fine. I am attaching the schematic with a 250W bulb connected as load.
I am out of my home station where I designed the hardware. The simulation is with me in my Laptop which I am sharing with you all. I used LRC meter to reduced the winding of my ferrite core which was already 500uH. I haven't used an air core yet as its difficult to get this value for an air core.
I will start a new thread soon with the devices pics.
Ali,
On the bench, are you seeing the currents indicated in the simulations?
What size wiring are you using from the tank circuit to the IRFPs and to the load?
A pic would really help here.
Quote from: JJUK on February 03, 2012, 12:43:35 PM
I'm sure it must be me being an idiot but I'm unable to open the ZIP files that people have uploaded regarding Ghazanfar Ali's Multisim simulation. (I'm an IT admin so I should know a little about such things!) The ZIP files download to my machine but then say they are invalid when I try to open them (see captured image). Is there something really simple that I'm doing wrong? Does everyone rename the extensions and if so, what extension should I be using? Still no joy if the file extension is renamed using .ms11 etc. I've tried from a number of different PCs but always the same result.
JJUK
JJUK,
I used a curl utility to download the zip and then unzipped.
If I used the browser it always complained about the file being invalid.
