aether22
Quote from: cosmoLV on February 03, 2012, 10:40:56 PM
P.S. I know that many has funny time to search this out, but this is not a game when you find the answer and see what kind of things and effects can be reached out of it. Then this is not a game â€" This is not a toy and never will be.
It generate its own magnetic field which is not depend of earths fields, without earth Grounding device produce too mutch power (but this is different story which are not related to Free Energy, there are more things not only FreeEnergy...
But all what can i say, that this secret not long stays in secret â€" we don't have choice.
I have no idea if Cosmo is for real or not, but clearly he is a tease.
I do however know that what he says about the danger in this technology is correct.
It is the engineering of the aether, the medium of matter, energy, space and time (consciousness, life).
Once you engineer the board on which the game is played you can change the rules.
Antigravity is just a level of shielding by energizing the aether that creates a shearing that gravity can't penetrate.
Lesser levels of sheering just cutoff EM fields.
You can energize matter to become invisible, this can occur from spark gaps and other conditions.
You can create, destroy and cause transmutation of matter.
Time can be effected.
Life energy can be created.
Consciousness can even manifest.
Obviously Tariel's device is not suited to do all this, but this can all be done with aetheric physics and sufficiently studied I believe a working device could lead to all these effects.
However if done right, the consciousness raising effects, the life energy that such devices can generate can ensure they are utilized by humanity to cause an age to come forth so wonderful we can barley imagine.
But to do this we must understand how this works and make a science of this.
By doing this and sharing the technology the world will forever be changed and we will be in control rather than be manipulated as we have been.
Addition
BTW my pick is that 1: the spark gap does not need to be in series with the caduceus tank circuit, having it discharge to ground (or if an AV plug it used, the negative) is fine and the oscillation in the tank should be fine. It may not collapse any longer though when the spark fires though.
2: It might require adding something else either to the experiment or to the environment, but having the caduceus tank circuit resonate as a lower frequency, maybe even 50hz will firstly be possible and might lead to increased output.
Alena
A man of high spirit, Tariel Kapanadze, conceals its secrets. But they are not hiding because people use them incorrectly. And because he wants money.
High Spirit Man Сosmolv hides his knowledge. Because it costs a lot higher than us in terms of consciousness.
Bow my knees before the Great! And behold my insignificance!
This is nonsense.
If the laboratory does not even Tariel Kapanadze oscilloscope, the effect should be evident? Why can not we see it? Obviously, building a chain of absurd from the standpoint of electrical engineering?
Ghazanfar_Ali
@ All who supported me and interested in my device
I have made the new thread as u requested.
Please let's start working on it. :)
Link is :-
http://www.overunity.com/11961/ghazanfar-ali-generator-utlilizing-trapped-energy/msg311552/#msg311552
Kind Regards
Ghazanfar Ali
T-1000
Quote from: wattsup on February 03, 2012, 06:43:28 PM
@T-1000
Thanks for posting the official diagram again. I am sure what you kindly took the time to put in bold does much more then that. But we shall see more soon enough. lol
Anyways, in the input pulse spec it says to utilize 200v at around 150mA (3 watts), 33% to 38% Duty, your particular freq, was at 16.8kHz and you had a 90% negative offset. So can I ask a few questions. Please, or if anyone knowledgeable is welcome to respond
1) How did you make the negative offset?
2) If you apply 3 watts at 33%, does that equate to 1 watt of actual applied power?
1) Bipolar generator can easily do that. For first find we used PCGU1000 to make flyback sing with less as possible consumed power.
2) The total wats consumed was metered, not part of the wave.
P.S> For those who use SIMS - you better assemble small Tesla coil and play with it. SIMS are much worse than real Tesla coils in field of OU...
Cheers!
Waves
" He's been kicked out from all russian forums, cuz he knows nothing". Hey fellows, iam surethat Cosmo knows
