0 Members and 80 Guests are viewing this topic.
conico
Thank you, Cosmo
In Delamorto device it is no coil inside ferrite, should I use a coil inside ?  Will be more energy out?
Alena
Quote from: a.king21 on February 04, 2012, 05:09:41 PM
I don't understand the way this thread is going.
Wesley has replicated the Lithuania experiment.
Looks like 30 watts in 200 watts out and probably even better than that.
Why don't those with the equipment simply replicate this and post some results?
That way we can probably design a circuit, instead of using expensive
signal generators etc.
Or am I missing something? :(
The device is in the process of repetition. While not getting a charge on Avramenko plug. Monday will continue. + Obviously a bad ground.
woopy
Hi all
going on my testing
here some results
hope this helps
and good luck at all
Laurent
http://www.youtube.com/watch?v=gz8GkK1tygQ
stivep
no you not
We do not know the mechanism that is ruling it
it is not major to get gain it is major to get  self looping
at no external power supply
Based on right principals.
Donald Smith got  gain and what?.... no progress.
Caduceus is tricky as you have to wind it exactly as Aidas did.
Ferrite yoke is even more.
Till now I do not  think I can give you something  that TK  presented with no need of any prove.
That is what NYW  is trying to achieve.
That is what  cosmoLV said he already has.
It is not even important   do we believe this guy..
TK did not used caduceus so mechanism is the most important . That is why TK presented big  power in Turkey
Wesley
cosmoLV
Quote from: conico on February 04, 2012, 05:35:55 PM
Thank you, Cosmo
Not always, you can do modifications as you wish â€" this thing is "big experiment" :)
Device is simple and there are no too complicated to modify something.
The most important thing is to organise HV impulses â€" the most simple way is to use Blocking generator in right arangment
Example is here: http://www.youtube.com/watch?feature=player_embedded&v=Sm-xKiStXBQ#!
"This is first step" you can make a simple Mini tesla coil â€" If you remember whyle ago i say importance of "Andrey Melnichenko" works
"The essence of the physical effect of generation of the free energy of the secondary field of the ferromagnet"
http://translate.google.com/translate?sl=ru&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fferromagnetic-energy.ru%2Farticles%2Fsut_fizicheskogo_e_ffekta1%2F
http://freeenergylt.narod2.ru/delamorto/kacer_delamorto.jpg
http://freeenergylt.narod2.ru/delamorto/DELAMORTO_2.jpg
P.S. Don't listen others here, they want not let you know about this â€" they are not interested in Free Energy, mostly is interest of self importance.
Keep your chakras opened :)
