0 Members and 477 Guests are viewing this topic.
blocki
Quote from: FreeEnergyInfo on February 05, 2012, 04:10:31 AM
VIDEO = FEIK ,BAD , MELAS , NO FREE ENERGY  !!!!
HISTORY DELETE VIDEO DELAMORTO ...
ANTANAS
LITHUANIA
ok, Thanks
@FreeEnergyInfo, how about the schematics that I posted last week, can I try to build this one:
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg310981/#msg310981
I'm really interested in building a device, but if it is proven bullshit, I won't start building it.
Thanks, blocki
itanimuLLi
conico
 This is my little Tesla coil.  The input is 20.2V ,1,13A DC . The output is 54.5V RMS, 0.54A RMS at 462.6KHz.
I use 0.6mm thin plastic tube for the coil of 300 turns. The copper tube inside must be close to this coil.
I believe in need a bigger coil with 500-600 turns.
aether22
Quote from: Khwartz on February 04, 2012, 04:48:59 PM
Hi aether22
<snip>
Very interesting viewpoint, could you develop? I mean, what makes you think that is like that, and if you have equations of this to predict it by calculation?
<snip>
See you eather22.
Hi Khwartz.
I have been studying Free Energy, Antigravity and various other unusual areas of physics for about 15 years.
By making the assumption that the majority of Free Energy devices and Antigravity claims and similar that had witnesses and other evidence are real I have then searched for correlations.
These correlations draw an increasingly clear picture.
On the subject of invisability, there are accounts in one or both of Gerry Vassalitos's books. (invisability from welding, arc welding I think)
Then there was a guy who made a scramble wound high voltage transformer (hmmm, caduceus like) and found that if he tossed steel screws near the arc they would disappear.
Then I was told by a friend how someone he knew stuck a steel coat hanger across a car battery and it got read hot, white and then started to go invisible.
Then I read about a guy who made a suit of steel coils that made him invisible and was showing it off.
Then I read a thing about someone who made a paperclip go invisible inside of a ring energized by a flyback.
I heard that Philo T. Pharnsworth (inventor of the TV) noted that steel parts in his fusor would become invisable.
and I heard from people I was on a list (Bill Beaty's Vortex) with and one of them had witnessed metal vacuum tube plates when run over powered going transparent or invisible.
Another (or the same) guy from that list reported a super thin waffer of gold became invisible when heated.
I was talking to someone, I forget who but someone in the US, when I was visiting there and he reported that he had seen/heard (I forget which) that when huge power system electrical generators don't supply energy to the grid they have been known to become invisible/transparent.
I read an account on Keelynet that again involves steel: [size=78%]http://www.textfiles.com/bbs/KEELYNET/UNCLASS/center1.asc[/size]
Troy Hurtubise (there was an old article about a similar invisibility ray I read once)
David Hudson, monatomics (invisibility of this substance has been reported)
I can think of a few others, but enough to show my point.
And for what it's work, the Philadelphia Experiment.
Now this is a slew of examples, but I believe that some of these have very good pedigree, some of them could be made up but then again no reason to believe they are.
Do they paint a consistent picture? Are correlations apparent?
In almost all of these we have metal, most often steel and some intense form of EM.
Now this just gives you a tiny look into how I gather and correlate info, other correlations that I'd stake my life on tell me there is a medium to space, and dollars to donuts it is involved in this invisibility effect. (there is other evidence to believe this)
Now it kinda makes sense doesn't it?
Light is an EM wave, if you overwhelm the electrons with energy (including electric, magnetic or heat) the electrons may find themselves unable to response (absorb) incoming photons.
Now effects from steel seem to be from the iron and what it does to the aether when the aether moves through it.
Antigravity, Teleportation and time travel and inducing lightening strikes have been reported multiple times and that is without bringing in the Philidelphia Experiment.
Now I can't do justice to 15 years worth of research, that is why I have just picked the cases for invisibility, it is up to you to decide if these show a correlation, point to a truth or not.
Different people have different ways of weighing up evidence, my method won't suit everyone, but it is designed to extract useful information from the leading/bleeding edge and if you accept the form of analysis it shows remarkable evidence.
What it doesn't do it tell you precisely reliably how to generate a given effect, it just creates a rough outline.
Do I think I know how TK's device works? Yes.
But I don't want to lead anyone up the garden path, I don't know if it is correct in this case. (though it is defiantly possible)
And no, I have not yet shared it as I doubt anyone will care.
But I don't want to distract from the important work being done by Wesley and his team, by Roberto, Woopy, Wattsup. Too much distraction lately.
Trumpet waveforms, that's what I am currently interested in!
note: Earlier I suggested a caduceus could resonate at 50hz, clearly the cap required would be insane, I didn't think the statement through.
BTW Roberto, or anyone, how much voltage is across the tank cap? More than 1000v?
T-1000
Quote from: Alena on February 04, 2012, 05:43:54 PM
The device is in the process of repetition. While not getting a charge on Avramenko plug. Monday will continue. + Obviously a bad ground.
"Период колебаний 10.4 мкс, Ñ,о есÑ,ÑŒ часÑ,оÑ,а резонанса 96.153 кÐ"ц.  The oscillation period 4.10 microseconds, that is, the resonance frequency 96,153kHz."
The capacitor on flyback is missing. So frequency of  96.153kHz is way too high..
Please see http://freeenergylt.narod2.ru/lithuania_experiment/schematic_of_device_with_caduceus_coil_and_pickup_coil.jpg on where flyback transformer capacitor is. It is important for this circuit to work with Avramenko plug over capacitive loop between Tesla coil primary and secondary coils.
You need to really understand about why there is capacitor in flyback making LC resonant circuit connected in series with high voltage coil.. :)
