0 Members and 41 Guests are viewing this topic.
cosmoLV
Only light radiation from sparkgap (if it is) depending on frequency â€" and it varies, depending from Ferrites, number of wire turns in coil, configuration etc..
i used Russian ferrite rings 40mm diameter outside 24.5mm inside â€" Factory label: "M2000HM1-17" (very hard to get it working)
better and easier with smaller diameters 32mm like "M2000HM" similar what used SR
With M2000HM you can catch the effect immediately â€" it is very easy! (frequency something around 20 â€" 30 KHz - using Blocking generator, mini tesla coil, or Flyback with adjustable ferrite â€" for frequency) use compas to see field â€" it detects field as soon you go in right frequency...
don't ask me about china ferrites and other manufacturers â€" newer tried these ferrites!
Keep your chakras opened :)
cosmoLV
P.S.John M  you can do this by simple experiment.
(smaler side of ferrite rings â€" for frequency adjust, pull it back (out of coil) for adjustment.)
old_physics_doc
@all
i am new to this forum. i have been monitoring the FE efforts for a couple of decades now but not publically several participating. i am familiar with Tom Bearden's theories and efforts as well as others. It seems that you guys are on the verge of a break through.
The group effort is a very good approach. However, i would strongly encourage you guys to document your efforts privately and keep a will secured copy of your work either with a trusted friend or in a very secure and secret location that can be passed on later. MANY researchers have lost their efforts by deceit or theft and not lived to tell about it.
i believe that we have arrived at a time when the FE nut is about to be cracked by the public and not reside in the hands of the "government".  Historically, the individuals who have solved the puzzle have been compromised by money, or fame or just "removed".
IF the method and construction is well documented and distributed then it will be much more difficult to destroy or control. This kind of public forum is only part of the answer. The rest of the answer remains to the individual researchers.
@cosmoslv
yes i believe that you are correct. The secret is crossing the ether/material barrier to extract energy from the ether. It appears that the method that Tesla used was the resonance frequency approach using high voltage and high frequencies.
Mannix
Quote from: hartiberlin on February 05, 2012, 10:47:20 AM
I got this message:
Stefan,
What they say in this video is of no consequence. There, they do not reveal how the device works.
Kapanadze generator is a modification of CZ 284 333, the three coil version. The modification consists of using pulsed HF generation (spark)  rather than the continuous wave as described in the patent. The spark is phase synchronized with the magnetic field modulation sine-wave (~50 Hz). The principle of operation is best seen in the pictures from Georgia, published by Wesley. Bare in mind that the fuel in this generator may be either Fe or Cu in the form of foil. I think, Kapanadze will reveal it sooner rather than later. Michel Meyer revealed it first in the Science et Vie article in March 1976.
You can assume the same, or very similar, for  Steven Mark devices.
If you wish, you can publish this information, omitting my name.
Now I found the Patent file:
http://worldwide.espacenet.com/publicationDetails/biblio?FT=D&date=19980812&DB=EPODOC&locale=en_EP&CC=CZ&NR=9603387A3&KC=A3&ND=5
Nuclear magnetic resonance is stimulated in a generator by the action of a magnetic field and electric current on an Fe 56 ferrous core, whereupon part of the current gained through conversion to Fe 54, is returned to the core, while the remaining part of the current is drained out of the equipment, allowing disconnection of the source and a self-sustaining process until exhaustion of the Fe 56. The apparatus for performing this method is a generator with a core in the form of an Fe 56 bar (2), support construction (1), inductors (6, 7, 8, 9), input from the source (11), necessary circuits and output. The device is equipped with a circuit for transfer of part of the gained current back to the bar (2).;  The device can be advantageously arranged with current output from the bar (2) split into two parts, one conducted to a regulator (14) for turning off the source (11) and the other conducted to the apparatus output.
Here is the attachment of the PDF file unfortunately in Cz language, but there are some pics at the end.
This would mean that we can use "scrap metal" as an energy source .
Finally, a rational explanation !
has anybody found an english translation ?
gyulasun
Microcontroller,
very interesting, thanks for explanations.
According to you,  what caused the heat in SM setups and did he solve it?
Thanks,  Gyula
