0 Members and 167 Guests are viewing this topic.
FreeEnergyInfo
Jury1
@FreeEnergyInfo
What is the role of the ionizer in your scheme? How do you want to get the electromagnetic induction in the T1? IMHO in such a scheme will not work.
aether22
I have just tried my theory with positive results!
I took a coaxial cable, shorted the 2 ends of the shield  together and one of the ends of the center conductor and connected it to the ground of my scope.
Then I took a reading off the free end.
I then got a 12v battery (needs recharging) and connected it up with a relay (my scope was powering the coil) and a pancake coil so it pulsed and produced a reading in the coaxial cable, so far so good.
I saw the reading on the scope and then fired up a HF HV supply (details below but unimportant).
The HV was rectified by microwave diodes, I connected the hv negative to the pancake coil, the reading increased greatly, I then attached the positive, no increase.
This seemed all very nice and clear and in agreement with my expectations.
I typed this message up, then thought to try something else out.
In doing so my function generator is now toast sadly. (the voltage from the TC like hv jumped the pins on the relay)
Not sure what I will do now for a function generator now.
I hoped to have the pickup coil charged positively, but that test will need to wait.
ronotte
Hi aether22,
I'm with you: its a picture I have seen when playing with TPU drivers...after some generators failuers I NEVER used directly the generator output but rather I'm alway using an high efficiency optically isolated  mosfet switch like the one built by JDO300. Just replacing the right mosfet you need  you are done ;) Mosfet mounted on socket. I've 6 of them I bought when playing with Spherics TPU.
I've some news on Caduceus/pickup coil update: I did the first impedance matching (using an SWR bridge) and now with only +10V to kacher I've on pickup output 500Vpp trumpet very easily. I'm now doing the output matching filter.
The selfrunner posted by Freenergyinput and designed by Antanas is interesting even if I think that in such a case the output should be killed by the two low load impedance. Practically I did the same a week ago trying to close the loop in the same way...noway to go :-[
The Ion wind generated is real: I did it several times..I think that purpose is to draw more energy directly from the aether itself. Of course without any measurement any comment is impossible.
Roberto
aether22
Good point Roberto! (pun not intended)
There is a guy, I forget his name but he uses insulated ionic wind generators (in other words points but no wind) and finds there is still motion generated, in other words the aether is being thrusted by the points, not just ions.
There is also Leon Sprink, he has 4 HV points 'pointing' towards each other.
This creates a large area where the aether is disturbed (churned up) changing the time it takes to produce cement, but it also disturbs gravity and changes many physical properties of the space.
http://www.rexresearch.com/sprink/sprink.htm
Also this is worth noting: http://sparkbangbuzz.com/corona-osc/corona-osc.htm
addition: I found it, His name is Borbás Miklós  His site is gone but:
http://www.electricimage.com.au/allan/Miklos_Tube.html
Actually this is kinda on topic too: http://www.electricimage.com.au/allan/Radiant.html
