0 Members and 36 Guests are viewing this topic.
stivep
Quote from: skaarj on February 06, 2012, 10:56:15 AM
@Wesley/stivep
2. You said that working with the caduceus causes some problems with health. Did you try to close the magnetic field with some other ferrite/iron (+some paper)?
best wishes
[skaarj]
not with caduceus but  with ferrite  from deflection yoke of old TV
That was  strong headache
With caduceus I did not notice any side effects
Wesley
hartiberlin
Quote from: microcontroller on February 05, 2012, 06:03:38 PM
Iron-56 (56Fe) is the most common isotope of iron.
About 91.754% of all iron is iron-56.
Iron (Fe) consists of four isotopes:54Fe,56Fe,57Fe and 58Fe.
This point is also where the whole dream alters since Steven Mark (and we) were always assuming the thing would run forever, but if iron56 is it's fuel it will run out, eventually.
Luckily we got 91.754% of all iron to go.
What's important to note here is that alternating magnetic fields running at certain specific frequencies can alter nuclear conversion between the elements thereby releasing energy.
Steven Mark was dead on with his words about the atomic energy commission and the connection with his device.
I won't go into any detail about how this mechanism works but i can tell you that when this 'nuclear event' happens small bursts of high energy (y-rays) are the result.
This is what Steven observed in his very first experiments and he rightfully called them kicks.
Notice this has got nothing to do with the earths magnetic field, but he had no idea about what was going on.
So what do you think would be the easiest way to generate these Kicks effectively ?
Many thanks.
Regards, Stefan.
aether22
I want to recover and expand my recent realization about how energy is received in resonant circuits.
But for a moment let's try something a little easier to grasp.
Let's say you have a DC generator and you increase the gap between the stator magnets and the rotor, the voltage induced into the rotor will reduce greatly.
You will have less voltage being produced at a given RPM.
One way of increasing the power created by the generator is to connect it with a high current power source.
How will putting in extra current help generate more? Well the voltage provided by the generator is now adding to a greater number of amps which means more energy out.
Of course this isn't free, increasing the rotors magnetic field will increase the negative motoring force.
We could do the same thing with an AC generator, just put a tuned capacitor in the circuit.
This is all well and good, but what does it have to do with free energy I hear you asking.
Well while learning how to gain more energy from a given voltage induced is nice, I think there is a Free Energy implication!
As far as I can tell, practical limits aside you could gain any amount of energy by simply putting in more amps, true in the above generator analogies you have to put in more energy to keep it rotating.
If we did the same thing with a transformer, we would get the same effects, more energy out but an equivilant loading on the input.
BUT, What if we are recieving free EM waves?
Rather than coupling to a near field. what if we picked up emitted radiation, what is the cost there?
Interestingly, I can't find one!
The EM wave has been created with a given unit of energy, but does that mean you can only gain that energy from it?
If more amps are flowing as the wave/photon induces it's voltage, then it induces more energy than if it was in an unexcited state it would seem.
So here we seem to have a loophole.
The only catches I can foresee is that either the receiving coil/wire may end up radiating it's self (though seemingly still OU).
And if it does might that wave travel back to the source and try to destroy energy there?
Of course it can't do that, the source could be an astronomical distance away and stopped existing eons ago.
So this seems quite a lot like Don Smith, maybe he was on to something.
My problem with this is that it doesn't employ the aether (unless photons do) and I kinda doubt free energy will show up without employing the aether.
Interestingly the circuit diagram posted above could (once some tuning elements are added) make this work!
If it was tuned to frequencies that have an abundance of power (500khz was used by Prentace) and if the ionizer regulated it's frequency and phase (triggered by incoming waves) so that it was in tune with the incoming waves then you have it.
That of course is not the same thing as easy, this requires either a very high Q circuit or some input power sacrificed to get enough current to oscillate in the tank.
What is interesting is that once you have the frequency and phase high with enough current in the tank you don't need really need the power signal to be much more dominant  than the rest of the background, different frequencies will have minor impact of adding and subtracting bits of energy randomly but it requires frequency and phase to be correct for it to have an impact on power.
I'd really like to hear some opinion on this, including if you understood it or not and if you agree or not.
Thanks.
hartiberlin
This is interesting:
http://www.youtube.com/watch%3Fv%3DkaIirh84aT0
A slow motion video of moving the transformer reveals
behind it that there might be a cable inside the big copper tube
with the around 5 windings ?
Or is it just the connection from the capacitor laying there on the table ?
On another picture I just saw the big copper coil looks pretty like flat wire,
not a holow tube...Hmm...
hartiberlin
Okay, let us try to make a circuit digramm from the 28th of April 2004 movie.
Look at the attached picture I found in the Russian forum.
The black box at the left, which is located in the movie below the table,
is a transformer with 4 diodes I have read.
So it is a bigger 220 Volts to 12 Volts AC to DC comverter which drives the battery and
the inverter.
