0 Members and 36 Guests are viewing this topic.
hartiberlin
Quote from: aether22 on February 08, 2012, 11:35:37 PM
You got that right and Hartman is leading the way by censoring posters that describe the process and burying information that does make it online. Watch for the rapid series of long posts right after a good post.
This is probably from User TheBuzz, who is still moderated, cause he disrupted all the threads some time ago and started flamewars
versus other users.
I did not censor this post, as it was not posted to this thread originally.
I wonder, if it will work without the ironwire at all without radioactive decay ?
Probably not, at least not with such huge COPs as Kapanadze is showing us...
Regards, Stefan.
aether22
I must admit that while I don't really like the idea, it does make reasonable sense.
But if this is the case then a gieger counter should give readings, I do have one somewhere...
Actually it could also be a semi-aetheric effect where the beta emission is a result of aether impulses exploding off the wire, Tesla coils and similar have always generated a radiant negative charge.
But iron might be able to enhance this.  This also makes sense in that my understanding is that as emitted beta radiation enhances any current it encounters, so all you would need to do is create the resonance and it will amplify it into a powerful current, or supply DC and it will amplify that.
This is making me think of Markovitch which used iron wire too: http://www.rexresearch.com/markovic/atree.htm
At the same time, I must say I very much disagree with your concept than the Newman machine works due to the carbon spark gap generating a voltage directly.
The impedance of the coil is huge and to overcome the applied voltage (many hundreds of volts) and the collapsing EMF (even larger) and they to spike current many times higher than the rate at which the applied voltage could would require a huge voltage that would cause voltage breakdown of the coil. (I have indeed killed 2 neon sign transformers with such external spikes)
In that case it must be generated within the coil.
Still I don't buy that free energy is based entirely on nuclear radiation, on the other hand nuclear radiation does stimulate the aether and the aether can create beta radiation by it's self.
Too many directions.
I am crystal clear that reception of EM can result in free energy, but I am unsure how to have a directional EM transfer between a transmitter and receiver at a frequency that I want to work with, that is to say that I don't like the idea of trying to do electrical engineering on frequencies of over 100mhz.
I think I need some lab time...
Shokac
Quote from: nightwind on February 08, 2012, 09:16:21 PM
Kapanandze Video: http://www.youtube.com/user/FreeEnergyLT#p/u/14/lFiaBKW50yA
At 5:54 , TK places a voltage sensing light probe (looks like a screwdriver) on the line & load side of the breaker that is turned off.  The light probe does not light up (no static voltage sensed?) on line or load side.  He switches the breaker on and the lights turn on........that is amazing.  Electricians use these to sense "hot" circuits.  I wished he had done it while the lights were burning.
NO!
Light probe LIGHT. Present 220V without Load.
Look again!
cosmoLV
Tariel always use a probe to check Live And Ground and he always use an AC â€" this device needs a correct AC source. no matter how he start it, but always there is inverted DC to AC.
Great that you pay attention on this!
1. What kind of device in the home teetering on the zero point - it should give a signal and it works then?
2. Another question. why transformer 220V to 12V? and why diodes are soldered as if there were rectified 220 volts? (about the last TK video)
(is not it the fact that there are some parts to drain away?)
P.S. Tariel is usual man without knowledge in electronics. by speciality he is Architect. But everybody thinks that without knowledge of electronics you connot make this device! Then tell me why these all super trouper electric engineers connot make it done? Because they connot think simple, they don't see laws of our nature and cannot find parallels in electricity...
They think that everything is hidden behind a gold shield, but all cnows that "Cup Of The Grail" are not golden plated.
They think that we need super power to run device, but this is not true!
Keep your chakras opened :)
rensseak
Quote from: hartiberlin on February 08, 2012, 11:20:35 PM
Wow, 24 known radioactive isotopes !
I did not know this...so probably all iron metals could be excited to radiate more
via High Voltage or strong magnetic pulses...
and release this way much more energy.
Hatte Edward Leedskalnin nicht mal erwähnt viel bessere Resultate mit Eisendraht zu haben?
Did not Edward Leedskalnin mentioned that he got much better results with iron wire?
On the other hand how you would explain all the other effects SM mentioned e.g. turbine effect, turns off upside down ?
