0 Members and 47 Guests are viewing this topic.
a.king21
core
Couple questions about the 2004 video.
At about the 5:00 minute mark Tariel sets up to start the device. It appears that the Signal generator (light blue box) is fed by 12 volts.
At 5:15 min he flips on the signal generator, there is no spark or load running, you only hear a buzz from a transformer.
At 5:30 min he plugs a cord in (It appears that this cord is wired into the back of the signal gen.) into the hot 220 volt bench outlet.
This bench outlet is not wired to the system but is being feed from an independent circuit. This can be seen at 5:41 min.
After plugging in to a separate power source (the 220v bench outlet) the spark gap ignites (after the 5:30 mark)
When spark is started he unplugs the 220 volt power supply (from signal gen?) and system runs on 12 volts and lights are energized.
He then takes the amp probe reading, input is about .5 amps. At that point the 220 volt line is disconnected.
Question:
What is this light blue device, a signal generator? If so what is the purpose of the second 220 volt A-C input?
Why do you think he needs to boost the system with a 220 volt line feed?
To start the process it appears that two(2) A-C power sources are needed. Because he unplugs one power source I get the impression that the operation is very similar, to a point, like a fluorescent lamp. Could the second power source (220volt bench line) be used to start the thermionic emission process? Then from there we get the process of impact ionization?
The role of the independent power source is odd and only needed to start the device.
-Core
Shokac
Quote from: core on February 09, 2012, 10:06:44 AM
Question:
-Core
Core, this is OLD UPS device.
They can not run without the 220​​. The first must have a source, only when there is no source can provide 220V to outlet.
Shokac
core
Quote from: Shokac on February 09, 2012, 10:30:25 AM
It appears that the UPS is wired to 12 volts (battery backup) At this point he is still getting an output from the UPS as he 'flips it on' before its plugged in to the independent wall outlet. Does he state in the video that it is a UPS? Whats the value of plugging it in? It already has power via the 12 volt battery. I'm not sure I understand.
-Core
