0 Members and 40 Guests are viewing this topic.
core
With the UPS wired to the battery and 'on' he already has 220v/50Hz. Why plug the cord in? How does that UPS work?
-Core
core
Quote from: Shokac on February 09, 2012, 10:34:31 AM
Again read this!
This is from TK patent.
When you read the patent description of the device you don't get the same picture as 'others' have stated it works. Maybe this is why everything is confusing? Reading the patent I get the impression of a current transformer momentarily being 'opened'.
Who really knows.
-Core
stivep
  Guthia- Wesley  Theory.             part 1
Text of article was
redone
chart1 revision 9 is attached
The reason for it is that Guthia from Georgia who is not associated with TK and he never seen him although both  are from Tbilisi have had conversation with me for quite few hours.He was trying to explain his thoughts to others and nobody would understand him.
At first it will look like I'm giving you complete nonsense.
for that I need you to think as if the nonsense is not nonsense.
1.Does surface of the earth have sine waves and/or  is able to carry on electrical waves?do not confuse  this question with  question #2
2. Does the earth responds to waveform?Well of course it does.short listing of FE causing factors:-magnetic field-electric field- electrostatics charge- mechanical  vibration - energy conversion by mechanisms of nature-seismic activity-friction4a. If AC voltage is present between legs of the man is that AC wave shape  sinusoidal?
  If we give answer YES than we confirm that rest of the structure of the earth  between  HV wire and the man  caries on AC sinusoidal signal
By that we conforming superposition of properties of AC signal in conductor including earth.
5. If two conductors in the circuit have AC 50Hz  when we dealing with floating ground (= no ground), than when we replace one of conductors with ground we should have  the same properties in that "conductor" as well ... obeying superposition rules So  fellows what is causing tungsten ( volfram) in light bulb to  dissipate energy  into  heat?
Current or voltage?
it must be current but if there is no voltage you do not have power.
The explanation will be that voltage is delivered by means of third point of reference.
That is what TK  might be able to achieveCould we say that by the means of manipulating  ZERO POINT OF VOLTAGE TK was able to achieve maximum current and no voltage?how did he do it?say by  using standing wave properties.
6.So why than the voltage delivered to TK device was  zero after initial impulse and current was  zero.?At 2004  presentation TK did not have (samozapitka) self looping as of yet . Or he was not presenting it.His device was similar to Doland Smith device using energy source.When he pulled  out the plug the device stop to give any response there was no longer light.but he had a ground wire connected...
The meter used to measure  V/A should be  AC capable to response at frequency of oscillation and at particular the highest pick ( pucziok) of current when voltage is zero of Standing Wave
That should be DIP METER not any regular clamp V/A meter.   you can not connect the V meter between two point if one of the points does not have relation to the point of reference.You take clamp meter  the current is in the conductor ,the voltage is not but  power equals  ZERO as V is zero than  meter can not show current as well.Got it?
Yes but  TK device was connected with one wire only ... the ground..... I agree..There is no such thing as one wire powering structure only... NOT by any means!!The circuit must be closed for the current to flow in AC CIRCUITS.
So what about Abramienko Fork..
Circuit will be always closed loop by means of electromagnetic or electrostatic  coupling.Yes we are delivering voltage to  one wire only in Abramienko Fork but we dealing with reverse signal path   upon that delivery due to  polarity of diodes.
The circuit closes due to electrostatic mechanism.
Ground=earth is there  or relation  of capacitive coupling between  two is there always.
7.So one say will Abramienko  Fork work in  altitude of 10Km?Yes it will work.The difference between ionospheric and ground potential= 45000Vanybody placed in between is under relation into ground  and/or  ionosphere. When  we increase capacitance  of the body we will create stronger relation .
8.So why the birds do not die on HV lines?Because the birds are on the same potential with no direct relation (-response) to points of reference.
9. So how to measure the voltage between two points heaving HV potential ( ground and HV wire) not connecting two points? We can use electrostatic V-meter.TK never used electrostatic V meter. And if he did It wil show voltage but we know without any doubts that HV is there ... only what we do not know is points of relation between points  As we may simply measure between points of known not points of unknown.
Electrostatic charge does not have frequency..It does have polarity and speed of change of polarity.Electrostatic charge has vector of direction.Electrostatic charge speed of change is not related to sinusoidal wave but is caused by it.It is mostly acting as a switch. You can not have  3/4 of polarity positive and 1/4 negative
At the certain point polarity changes rapidly with the speed of light  or speed of electron traveling in given medium.
Electrostatic charge can not have any % of positive and negative potential at one given point of wire due to relation  of that point in wire to ground
it is one or the opposite one at given point in time
O boy... I just found interesting something here...SWITCH?  ??..............Burst of  energy............Created by sign wave?
Polarity of static electric field will change always rapidly while sign wave causing it will change voltage and current  gradually. That is your switch.
That means that electrostatic field responds to sign wave by means of square  wave mechanism. By that electrostatic field is causing environmental response of rapid nature . Environment is answering with rapid interaction. TK uses HV to create ionization and stronger relation between two environments...If  there must be always closed circuit than wire of circuit between TK cevice is ground wire and the second one is Electrostatic switch..In Aquarium and in Green box he used 2 ground wires  heaving distance  between the wires.correct me if I'm wrong..But he uses  a lot of load there.I recall  -faucet with cold water pipe  that is ground #1 and -radiator from old automobile deep in to the ground and water poured.   ground # 2The distance between points of  ground is our conductor that should obey  superposition rule.
10.  Can anyone from you point to me where wires from two grounds have been connected on the device?
Wesley
energia9
I have the simplest logical idea on Tesla /kapanadze device.  only if you are interrested and not ignoring it.
will this site acceppt word document file?
xenomorphlabs
If that light blue box is an emergency UPS, then it could be that it requires mains power first and then senses the removal of that and switches to battery
HOWEVER the exact same light blue box has been used in the green box presentation WITHOUT mains power for startup which
lead me to believe that it is a 12 V DC inverter.
So Core's question is absolutely justified, why would it need a mains startup on the workbench, when in the outside green box
presentation it hadn't needed it ?
Only answer that i can think of is connected to the difference of starting the device up
in the 2 presentations.
In the green box presentation,the first switch was used, then he waited like 5 seconds and then flipped the 2nd switch.
On the workbench there is only 1 switch.
So it could be that a capacitor was charged with the first switch in the green box to provide a huge startup current to get the device running.
After all it was also looping back on itself.
