0 Members and 42 Guests are viewing this topic.
Kator01
Quote from: hartiberlin on February 08, 2012, 10:51:59 PM
You get this green plastic hull isolated iron wire in each garden store.
It is used for plants and fences...
It is also pretty cheap.
Hope this helps.
Regards, Stefan.
@Stephan: the isolation of these wires are just a very thin green varnish and can not handle any higher voltage so you will get shorts between the windings. I buyed some cheap copper-cable ( solid version, no filaments) diameter 1.2 ( equals 1.5 mm exp2), stripped the plastik-isolation off in one piece ( 1 meter is possible without damaging the isolation ) then I took some 1 mm dia bare iron-wire put it through the isolation. It works because iron-dia is 0,2 smaller than the copper-wire fitted within this isolation.
Kator01
27Bubba
Is it possible that TK knowing that the whole thing is videotaped,  used extra steps as DECOY! By watching the video again, I sense that something is not "culture"...
core
Kinda off topic but relevant to Free Energy.  This quote from Neil Keenan. This man filed a law suit in New York against some BIG players.
WHAT DO YOU WANT TO DO NEXT?
NK: There are many things to do. One of the things I will be doing almost immediately is to activate our Free Energy initiatives.
Everything is all set to go right now. We just need the security to move forward without our people being killed.
Numerous nations are already requesting it, and every nation will demand it once they know it is real. This is the end of the OIL & GAS era the Cabal had us choking on.
Looks like Mr Keenan is into the FE thing......thats good to hear.
-Core
cosmoLV
Quote from: core on February 09, 2012, 10:42:04 AM
With the UPS wired to the battery and 'on' he already has 220v/50Hz. Why plug the cord in? How does that UPS work?
-Core
This is an old soviet inverter.
The characteristic of device is that you need a inversion â€" the main reason is to isolate from AC "industrial Ground" /Device has own earth ground/ from ground electricity are not pumped out!
Anyway it needs a AC â€" this is important.
Tesla worked with AC currents â€" don`t foregt this!
Keep your chakras opened :)
