0 Members and 40 Guests are viewing this topic.
cosmoLV
Quote from: hartiberlin on February 09, 2012, 07:15:34 PM
Hi,
I uploaded this original video in 720x576 in FLV Format over here:
http://www.2shared.com/video/ELhqwFB1/coil.html
You can use the free Videolan.org VLC player to play it.
Regards, Stefan.
if you need i have original video â€" about 9 Gb, recorded directly from VHS tape!
need to be compressed as MPEG DVD, so in total will be about a 1GB
Keep your chakras opened :)
27Bubba
@ cosmoLV
Hi while back you pointed this link(below) as possible as something to try. Well, I have started but the problems I'm up against are some of the components used. Those are typical Russian power transistors Kt-827, Kt 825 (can locate those in the Us) Also I have no idea what the K561La7 is... Any suggestions?
Thanks
  http://freeenergylt.narod2.ru/delamorto
hartiberlin
Here are some more clues:
microcontroller wrote to me:
If you don't want the power but to see just a glimpse of the kicks you can simply wind a double interleaved coil one lead copper one lead iron like so:
http://i43.tinypic.com/120mcjp.jpg
Drill small holes for the wires like so:
http://i40.tinypic.com/a2dkps.jpg
Make sure it's wound like so:
http://i44.tinypic.com/2drb0ow.jpg
Wind them interleaved but make sure they stay as two separate coils, they are in no way electrically connected to each other.
When this coil is connected to a transistor like is explained exactly in the Carl Doc, one lead serves as trigger the other lead for output, it will act like a blocking oscillator and you can tune it to produce audible tones, and you have a good coil when it reacts heavily to the earths magnetic field.
By this i mean when it produces a steady tone and you move it the frequency will change dramatically.
Of course it will also respond to a magnet and it can respond to both at the same time if the fields correctly blend into each other.
Take it to the next level by hooking it up to a signal source and a scope, and raise the frequency watching the scope carefully.
and another message I received for posting:
To further stimulate the discussion on isotopes, please notice that copper has isotopes too.
Indeed, M. Meyer used copper in his early experiments (http://www.rexresearch.com/meyernmr/meyer.htm). Don Smith used copper as well. Meyer, Smith, Mark, TK, T-1000 ... it is all connected, it is ... NMR stimulated transmutation.
Another clue to the puzzle is on page 116 in "Space Science" book, Imperial College Press, edited by L.K.Harra & K.O.Mason (do not be spooked by the title).
hartiberlin
Quote from: cosmoLV on February 09, 2012, 07:20:05 PM
WHat exact videos do you have of Tariel Kapanadze devices ?
Most videos are okay on youtube resolution to watch, as there are too many components on there
to decrypt.
Do you have any movies that were not yet posted to youtube of any presentation ?
Many thanks.
Regards, Stefan.
cosmoLV
Quote from: 27Bubba on February 09, 2012, 07:37:57 PM
@ cosmoLV
Thanks
You can use different transistors without a problem. By the way Russian transistors have one problem, they are weak to HV and other â€" you can easily burn it out when short circuited!
i think the Kt-827, Kt 825 are bad. i have burned while experimenting, all these out! :) they are too sensitive! By the way Kt-827, Kt 825 are Audio Amplifier Transistors.
better is to use:
MJL21193, MJL21194 or the best on my opinion is TIP2955, TIP3055 they are not so powerful as MJL but have a great characteristics on HV devices hard to burn out.
This is the list what i used:
MJL21193, MJL21194
2SA1943, 2SC5200
TIP2955, TIP3055
For all time in 5, 6 years i burned out in experiments something about 15 - 20 of these (they are expensive, but powerfull)
