0 Members and 127 Guests are viewing this topic.
27Bubba
@cosmoLV
I have no idea what the " K561La7"  is... Any suggestions? Can not reference to any thing...
Thanks.
cosmoLV
Quote from: 27Bubba on February 09, 2012, 08:53:52 PM
@cosmoLV
Thanks.
The analog of K561LA7 are CD4011
Keep your chakras opened :)
27Bubba
cosmoLV
Quote from: 27Bubba on February 09, 2012, 09:23:05 PM
Thank you CosmoLV.
What pin numbers are used?
i never ben worked with CD4011, i better like CD4017  (i'm too lazy to dive in to datasheet) :)
i draw by quick hand for you schematics:
Signal IN (is signal input from blocking generator)
Signal OUT â€" to transistors "you can use one out or both on each transistor"
12v voltage stabiliser to 5volts with filter are protected from HV Spikes to protect IC
schematics and parts PCB:
(in attachment is PCB etch .pdf)
cosmoLV
27Bubba
P.S. Or if you like very simple and easy â€" you can make a simple "Frequency Divider"
like this one:
(R1C1 of the circuit above can therefore be adjusted to define the number of input pulses equivalent to a single output pulse. Thus, this circuit is in effect dividing the input frequency by an integer.)
