0 Members and 91 Guests are viewing this topic.
TheCell
@m786
In the magnetic amplifier example you connect the low voltage sides of the 2 transformers against each other so that the voltages induced by the 2 high voltage sides cancel each other.
Now you apply a small dc current and so you shift the working point in both transformers into the non linear region and thereby changing the inductance , and thereby varying the current in the lamp. NO OU.
The other circuit relies on the principle of SR193 .
But there is something wrong:
The HV/4 frequency : no there should by 50hz applied.
A flyback circuit generates the high voltage that is fed through the sparc gap and since one end of the high voltage coil is grounded this HV coil will establish a standing wave with oscillating peak at the other end. And this fact is related to a lambda/4 wave.
The sparc gap is hammering via the pulses to the core and there occurs isotropic transmutation of FE 56 to FE54 which results in an energy gain at the output.
m786
Quote from: TheCell on February 10, 2012, 06:41:20 AM
@m786
Magnetic amplifier is there just to show Principe ,how to change some parameters like induction in time. If you are changing induction in right time,then you can excite oscilator and increase energy in system, that is OU in that case.Pls read that document about parametric excitation.
scratchrobot
Quote from: m786 on February 10, 2012, 07:19:44 AM
https://rapidshare.com/files/4282179852/Parametric_excitation_of_electric_oscillations__In_English_.doc
27Bubba
stivep
Lithuania Experiment 2012 NYW group Video #1 (Aidas 3W in
100W out
With laser tube even more.,
We no longer try to  fallow particular concept..
MECHANISM IS THE KEY.
So  Aidas played with thyratron  and  drop it upon my advice as I was dealing with much simpler valve 1b40
He utilized  small toroidal  bifilar transformer, connected to PCB based bipolar  power supply- amplifier. generator, than Penthode is a party of the circuitry ... About 350-500V is delivered from that  to Flyback  that has   manufacturer build in capacitor.
And than Load is connected with one wire only...
But again there is no circuit working with one  wire.... so loop is closed by electrostatic/ electromagnetic mechanism.,..
http://www.youtube.com/watch?v=ph87G4RxURw&feature=youtu.be
Wesley
