dole
Quote from: stivep on February 10, 2012, 09:15:16 AM
Lithuania Experiment 2012 NYW group Video #1 (Aidas 3W in
100W out
With laser tube even more.,
We no longer try to  fallow particular concept..
MECHANISM IS THE KEY.
So  Aidas played with thyratron  and  drop it upon my advice as I was dealing with much simpler valve 1b40
He utilized  small toroidal  bifilar transformer, connected to PCB based bipolar  power supply- amplifier. generator, than Penthode is a party of the circuitry ... About 350-500V is delivered from that  to Flyback  that has   manufacturer build in capacitor.
And than Load is connected with one wire only...
But again there is no circuit working with one  wire.... so loop is closed by electrostatic/ electromagnetic mechanism.,..
http://www.youtube.com/watch?v=ph87G4RxURw&feature=youtu.be
Wesley
@Stivep
Would you be so kind to ask your fried to adjust the multimeter correctly (at 19:40min), either to mA or to A scale according to the multimeter wires connected, otherwise it may show wrong amperage measurement.
Simply, everyone can make a test with light bulb at 110/220V AC and the multimeter wires connected to measure amperage at 10A, and then turn scale to mA.
I have seen many videos on the internet showing input as output and output as input in this way.
Apologies if I am wrong and thanks for your great effort.
:)ole
aether22
Wesley, while I don't you try this:
http://www.google.com/patents/US4290070
Your big core naturally has a split in the middle, the claim of this patent is that by putting carbon (or possibly other diamagnetic) in the middle, an excess of energy is created as the magnetic field becomes significantly more powerful.
This says it is an amplifier, but an unpowered amplifier is actually a source of free energy.
Here is the thing, we don't know how Kapanadze did it.
We don't know how SR did it.
We don't know how Steve Marks did what he did.
But what we do have is the caduceus device that you have working, but right now we don't know how you are doing it!
No one has yet been able to replicate the power output, so far that SEEMS to be due to the lack of a resonant tank circuit on the HV generator.
At least that is the only theory.
So I think wattsup is right, we must concentrate on this element, if it is removed is there still light output? If so is it OU?
Can we a add this element to a kacher type device and then produce light?
If this element is critical, then what happens if we adjust it to a lower frequency, then what?
Wesley, if you have OU and it seems you really do, then let's find out what is going on.
This is an exceptional opportunity and let's not miss it.
Also, do you get lights powering up and OU without the trumpet waveform?
Addition: Dole, your concern must be addressed.
But if it were reading amps instead of ma then when it reads over 30, 30A at 230v? volts is 6.9KW.
Clearly it isn't drawing that much power!
Addition 2: I want to just make a simple argument for it not mattering where energy comes from, and that maybe it can be created under the right circumstances.
It is well known that if you double velocity, you have 4 times the energy.
Therefore if you have a device that produces uniform reactionless thrust it must violate the conservation of energy. (unless energy just mysteriously disappears from somewhere else to make it up)
Borbás Miklós's experiment and various others have shown that reactionless thrust can be produced, these could easily be used to generate free energy.
John M
Quote from: stivep on February 10, 2012, 01:29:35 PM
Copy of my response to Letter of one  of very active famous YouTube activists in  FE.
The rest will be given   anyhow.
No secrets
Wesley
PS: I really want this to get out before end of 2012.
Wesley - It is great you are moving in this direction. I have read on and on about replications talking about frequency, number of turns etc. This would be good if a lot of people had successful replications based on specific information, but most do not. Undoubtedly people, myself included build their own variation from what they have lying around. I fully understand when you talk about reference (potential voltage between two points) but still can't comprehend where the current comes from. Any explanation is still just theory at this point to me and is probably what you are referring to as the mechanism.
John
ZeroFossilFuel
No secrets
Wesley
(sigh) Wesley, what exactly is your intent for reposting this private message to me here on a public forum? To prove you're being evasive? Mission accomplished. I will not burden you with any more questions.
Z
My public PGP key. Please help support my work. Donate by PayPal
Qwert
Since the RESONANCE makes some difficulties to some folks, I think this document may help them; I guess, reading page 5 and down, can bring some help:
http://www.panaceauniversity.org/Magnetic%20Resonant%20Amplifier.pdf
