0 Members and 40 Guests are viewing this topic.
stivep
Quote from: ZeroFossilFuel on February 10, 2012, 10:49:15 PM
(sigh) Wesley, what exactly is your intent for reposting this private message to me here on a public forum? To prove you're being evasive? Mission accomplished. I will not burden you with any more questions.
Z
At first I did not mentioned  your name here.
At second I expressed respect
At third  message to you could not be send  Because of:
error show : verification procedure in red color.... or  message could not be send because  authenticity
procedure   when I was clicking to send from my Youtube inbox
Than I tried instead  to go to your YouTube side and send it directly from your account as a message
At the end there was no choice but give you answer here...
Obviously you got it anyhow. Probably from your YouTube account.
It is easy to blame  person for his good approach. And make him of one he never  intended to be...Do you see the point?
Wesley
PS: what I noticed is happening ... YouTube= Google "may" :)  try to force users to give out their telephone address and contact information.
That is for old  email  holders.
The reason??  "may be" invasion of privacy
I'm dealing with very much delicate subject.. Hundreds of times i have seen :
"Please give your  telephone in case your mail is lost..." to recover your account.
and so on......... Definitely they want  100% prove that they can easy find the person if there is need for it.
But this error message I have seen for the first time.
scratchrobot
Quote from: stivep on February 10, 2012, 09:15:16 AM
Lithuania Experiment 2012 NYW group Video #1 (Aidas 3W in
100W out
With laser tube even more.,
Sound good, 3W in 100W out!
What else do you want??
forest
Quote from: scratchrobot on February 11, 2012, 09:23:26 AM
Think.... there is only one reliable proof . Do you believe Kapanadze got OU ? Why do you believe ?  ::)
hartiberlin
100W out
http://www.youtube.com/watch?v=ph87G4RxURw&feature=youtu.be
Wesley
Hi Wesley and team,
thanks for your contineous efforts to try to get more power out of your circuits.
But I don´t think this bulb shows 100 Watts output.
If this would be true your whole room would be illuminated at 100 Watts.
If that  is a 100 Watts light bulb it is right now probably only showing 5 to 10 Watts at maximum...
So you are also far away from the COP = 86 that Kapanadze showed in the 2004
video with his simple coil.
Also as in this 2004 video there are no big ground wires put through the core hole,
I wonder why he did this in the later videos ?
Does it have any effect to put the ground wire through the hole inside the core ?
Who has measured this already with a scope and can show the difference with some scope shots ?
As the 2004 video does not show this, it seems that this has not a big effect and maybe was
only done later for convenience to sort out all the cable mess and routing inside the coil
but nor for power amplification ?
Wesley, did you see at your visit in Georgia, what material Kapanadze has as the core in his coil ?
Was it just ferrite  rings or also a copper tube or any other metal tube inside the hole ?
Many thanks.
Regards, Stefan.
hartiberlin
Quote from: TheCell on February 10, 2012, 06:41:20 AM
@m786
In the magnetic amplifier example you connect the low voltage sides of the 2 transformers against each other so that the voltages induced by the 2 high voltage sides cancel each other.
Now you apply a small dc current and so you shift the working point in both transformers into the non linear region and thereby changing the inductance , and thereby varying the current in the lamp. NO OU.
The other circuit relies on the principle of SR193 .
But there is something wrong:
The HV/4 frequency : no there should by 50hz applied.
A flyback circuit generates the high voltage that is fed through the sparc gap and since one end of the high voltage coil is grounded this HV coil will establish a standing wave with oscillating peak at the other end. And this fact is related to a lambda/4 wave.
The sparc gap is hammering via the pulses to the core and there occurs isotropic transmutation of FE 56 to FE54 which results in an energy gain at the output.
Hi,
do you think the High Voltage from the sparkgap is synchronized to the 50 Hz pulses ?
Does the sparkgap spark also jumps with 50 Hz frequency or is it faster ?
Is the 50 Hz oscillator inside the round box in the 2004 video ?
Is the ground wire really nessessary ?
If yes, does it pull free electrons from the ground in or does the OU energy come
from the NMR transmutation of the iron isotopes from the iron wire or iron ferrite core ?
So what is most logical explanation how Kapanadze could get COP= 86 with his circuit ?
Many thanks.
Regards, Stefan.
