0 Members and 40 Guests are viewing this topic.
scratchrobot
Quote from: forest on February 11, 2012, 12:07:49 PM
Think.... there is only one reliable proof . Do you believe Kapanadze got OU ? Why do you believe ?  ::)
I have not seen reliable proof of OU, also not from Kapanadze but I believe.
I'm only saying that when I would have found circuit with 3W in 100W out I would make simple short video with schematic so everybody could replicate.
Don't Think, Experiment  ;)
hartiberlin
Quote from: ronotte on February 09, 2012, 05:26:51 AM
Hi Harti,
your hypothesis is intriguing: Fe decay with strong beta emission could (?) explain the COP=86. Yes, we are not speaking about COP=1.xx hence the difference is mainly not due to standard well known electrical laws. So the 'garden' isolated iron wire usage does remember me the work done by otto, giantkiller and others (not myself, I always used copper wires)...anyway they all did not reached any OU (in my knowledge) not speaking of giant COP figure you mentioned.
All the other hypothesis about standing wave manipulation in wires or Copper pipes even if sounding I see it difficult to explain the COP showed by K and far from the K man knowledge: too complex. V Utkin is perhaps the more close to K device...but I think only partially. For example I proved the 'blinding' effect on the wesley's pickup coil, the trumpet wave on output...but until now 'checked' overall effects are light years behind what showed by K. I succeeded in adapting HV source impedance with Caduceus input (great!!...)...but until now I've had no results in matching the pickup coil output to load: a very difficult task.
So your Fe decay beta emission could be a way...BUT REMEMBER THAT IN ORDER TO STIMULATE A HUGE BETA DECAY IS IS NECESSARY TO DELIVER IT (the Fe electrons) > 8Mev (Mega ElettronVolt) energy as stated in my previous post, using our poor-man capabilities we actually are able to impart only Kev range of energies (max of 20KV ... normal TBC usable output is far less and also my kacher output max 2KV under load condition). 8Mev are typical of linear or torus Accelerators machines I used to work with in my far past. The eventual small effect possible  at 2-6Kev should be considered marginal, certainly not accountable for COP=86. But...what if K found a way to enhance the effect while in a positive loop? May be that peak energy suddenly rockets to Mev range for combined effects due to 1/4 wave resonation, standing wave build up, mechanical ferrite rod resonation, earth current, etc...so establishing a sort of avalanche effects. Well, only my own rumblings.
At the end it seems impossible (?) to me that we eventually could be able to obtain such effect just sliding  Fe wire into copper pipe coil (K always uses a big copper pipe but I do not remember to have seen any wire protruding...).
Anyway in the course of my FE experience I tried several time to check TPU for alfa, beta or gamma emission using professional nuclear detectors: never found any even small evidence (it must be said that I checked My TPUs so no iron wires...).
Roberto
Hi Roberto and all.
If Kapanadze has found a process that uses excited Beta Decay of Iron isotopes,
there must be an easy circuit that triggers this release of beta decay.
Maybe it is much simpler just to research this basic effect.
Just take a spool of iron garden wire and pulse it with a high Voltage
sparkgap and see, how the impulse answer is you get on the iron wire with a scope.
Does the high voltage pulse onto the iron wire generate a huge radio frequency burst
in the iron wire ?
Also connect the iron wire spool with its other end to ground and see, if the impulse answer is different
then.
How does the impulse look on the scope ?
What is its amplitude ?
Can we see, that there is a bigger energy released inside the impluse answer of the spool of iron,
than was fed in via the spark pulse ?
Will 2 alufoils put over and under the iron spool charge up from beta radiation ?
how does the waveform then look on these 2 alufoils on the scope ?
As this is a capacitor it should charge up due to beta radiation ( flying off electrons from the iron coil)
Regards, Stefan.
ZeroFossilFuel
Quote from: stivep on February 11, 2012, 08:14:12 AM
At first I did not mentioned  your name here.
At second I expressed respect
At third  message to you could not be send  Because of:
error show : verification procedure in red color.... or  message could not be send because  authenticity
procedure   when I was clicking to send from my Youtube inbox
Than I tried instead  to go to your YouTube side and send it directly from your account as a message
At the end there was no choice but give you answer here...
Obviously you got it anyhow. Probably from your YouTube account.
It is easy to blame  person for his good approach. And make him of one he never  intended to be...Do you see the point?
Wesley
PS: what I noticed is happening ... YouTube= Google "may" :)  try to force users to give out their telephone address and contact information.
That is for old  email  holders.
The reason??  "may be" invasion of privacy
I'm dealing with very much delicate subject.. Hundreds of times i have seen :
"Please give your  telephone in case your mail is lost..." to recover your account.
and so on......... Definitely they want  100% prove that they can easy find the person if there is need for it.
But this error message I have seen for the first time.
At first, you did not have to mention me. The message was still private.
At second, by posting a private message that is debatable.
At third, YouTube messaging in general is screwed up right now. Harti and I had the same problem. Many complaints. You are not being singled out and it does not mean you are a target of some sort.
I have earned a reputation of being trustworthy. Since you do not live too far from me, all I asked you was that I be allowed to come view your work. You launched into that great big long diatribe. Fine. To each his own. I believe you are being your own worst enemy. That's my own opinion and you know what they say about opinions. Everyone has one and they all stink.
Again, I will not bother you with such trivial requests again. I hope you are successful.
Z
My public PGP key. Please help support my work. Donate by PayPal
Magluvin
Quote from: hartiberlin on February 11, 2012, 01:22:59 PM
Regards, Stefan.
Ive thought on this a few times before.
But what determines which foil plate is positive and the other negative?
Or, maybe the plates would be of the same polarity and would need an earth ground for use.
And having 2 separated plates just keeps them from being an inductive winding causing unnecessary losses.
Mags
stivep
Quote from: hartiberlin on February 11, 2012, 12:45:07 PM
Hi,
Regards, Stefan.
I'm talking to group Aidas Arunas Alona (woman active here), Niko from Zariad
he just mentioned that laser that was used in experiment was around 1KW
The answer was they will prepare more evidence
I ask them to find model number and spec  for this laser.
And again ....They did not object to provide  more evidence.
On video I  said that Aidas uses  microscope camera  with back-light compensation and that his room is at full light but camera  see it  this way.
When Aidas disconnected light completely for the moment he switched microscope  to ultraviolet.
Than you have seen total darkness
Wesley
