xenomorphlabs
Quote from: hartiberlin on February 11, 2012, 12:45:07 PM
Hi,
do you think the High Voltage from the sparkgap is synchronized to the 50 Hz pulses ?
Does the sparkgap spark also jumps with 50 Hz frequency or is it faster ?
Is the 50 Hz oscillator inside the round box in the 2004 video ?
Is the ground wire really nessessary ?
If yes, does it pull free electrons from the ground in or does the OU energy come
from the NMR transmutation of the iron isotopes from the iron wire or iron ferrite core ?
So what is most logical explanation how Kapanadze could get COP= 86 with his circuit ?
Many thanks.
Regards, Stefan.
In TK's patent it is mentioned that a high frequency signal is being used.
If the same concept applies to all his devices then this would not point to 50 Hz being used
for the spark gap.
It seems as if he feeds the 50 Hz @ 220V from the inverter directly into the secondary coil
finding a way to amplify the current. Patent speaks of current amplification.
In theory there are not just 2 single methods to achieve that (Displacement or FE56),
one has to consider others.
Also mentioned several times through the patent is that a magnetic field of high strength
is being created between the coils.
Strong magnetic field = strong current obvious.
I am just thinking if the TK principle would NOT be based on a magnetic effect at all
and use beta decay or something else, the patent would be on the edge of correctness...
Except of course it only applies to a singular unit (maybe even no-one has seen)
and is a decoy and all other devices are based on an entirely different principle (unlikely)
hartiberlin
Quote from: ZeroFossilFuel on February 11, 2012, 02:52:12 PM
At third, YouTube messaging in general is screwed up right now. Harti and I had the same problem. Many complaints. You are not being singled out and it does not mean you are a target of some sort.
Yes, that is true. Youtube messages are screwed up in this moment.
Replys do not work.
Regards, Stefan.
hartiberlin
Quote from: stivep on February 11, 2012, 04:20:34 PM
I'm talking to group Aidas Arunas Alona (woman active here), Niko from Zariad
he just mentioned that laser that was used in experiment was around 1KW
The answer was they will prepare more evidence
I ask them to find model number and spec  for this laser.
And again ....They did not object to provide  more evidence.
On video I  said that Aidas uses  microscope camera  with back-light compensation and that his room is at full light but camera  see it  this way.
When Aidas disconnected light completely for the moment he switched microscope  to ultraviolet.
Than you have seen total darkness
Wesley
Hi Wesley, maybe he can film it then with a normal camera and he could place a normal 100 Watts bulb besides
it beimg lit by normal AC voltage, so we could compare the brightness ?
Many thanks in advance.
Regards, Stefan.
ronotte
Hi Stefan,
I mostly agree with you. THANKS for your lucid exposition. As a result I certainly think to make soon some test with the garden iron wire spool I've using kacher  Spark gap as HV high freq source (in practice the first part of my caduceus/pickup coil device). It should be interesting to see the behaviour of different coil geometries including bifilars made of CU-Fe and the use of alufoil coil as output. I'll report if any relevant results
Roberto
captainkt
Hi Stephan
I am also in full agreement with what you are saying. After years of fiddling with coils I can now easily go in to my shed and using an NST with spark gap and caps light up 200 watts but what I am looking for is the secret and I think simple way to get the 10 times that amount that Kapanadze does.
Now going to try iron wire mixed with copper and DC mixed with HV. I would have thought after over 700 pages something would be obvious, will keep trying.
Keith
