0 Members and 130 Guests are viewing this topic.
Kator01
Quote from: TEKTRON on February 10, 2012, 03:15:36 AM
KATOR, HERE IS SOLID 14 GAGE STEEL WIRE WITH PVC INSULATION
http://www.ebay.com/itm/HILLMAN-PLASTIC-COATED-STEEL-CLOTHESLINE-WIRE-50FT-NEW-/390186179115?pt=LH_DefaultDomain_0&hash=item5ad8e89a2b
Hello Tektron,
thank your, now I get the idea and can look for cables here in germany. These clothling-cables are mostly pure plastic here, but I know there are some manufactures who produce iron-litz-wire with a soft plastic-isolation.
It is a soft, transparent and very thick plastic which will not stay the high voltage so an additional isolation has to be applied.
Reards
Kator01
John M
Quote from: hartiberlin on February 11, 2012, 01:22:59 PM
Hi Roberto and all.
If Kapanadze has found a process that uses excited Beta Decay of Iron isotopes,
there must be an easy circuit that triggers this release of beta decay.
Maybe it is much simpler just to research this basic effect.
Just take a spool of iron garden wire and pulse it with a high Voltage
sparkgap and see, how the impulse answer is you get on the iron wire with a scope.
Does the high voltage pulse onto the iron wire generate a huge radio frequency burst
in the iron wire ?
Also connect the iron wire spool with its other end to ground and see, if the impulse answer is different
then.
How does the impulse look on the scope ?
What is its amplitude ?
Can we see, that there is a bigger energy released inside the impluse answer of the spool of iron,
than was fed in via the spark pulse ?
Will 2 alufoils put over and under the iron spool charge up from beta radiation ?
how does the waveform then look on these 2 alufoils on the scope ?
As this is a capacitor it should charge up due to beta radiation ( flying off electrons from the iron coil)
Regards, Stefan.
Stefan - Excellent suggestions for experimentation with iron wire. It always bothered me that kapanadze videos showed so many different devices where it was said that after his demonstration he would dismantle them. This would indicate that he can easily create a working device. Iron wire could be the Holy Grail of the device that is not easily discerned from any video. That said, is the two grounds just to mislead people? Although Don Smith said it was necessary for his devices to work, but others just recommended and showed that some other mass such as a metal plate is all that is needed to get the electrostatic coupling. For higher power it may be necessary to provide ground.
I also thought Wesley's video needs some explanation (light output) and I am sure he will provide it.
John
forest
Kator01
Quote from: energia9 on February 10, 2012, 06:21:57 AM
Thank you Kator.
download pdf.
read carefully to get the feeling.
@energia9, m786 :
  • Hi energia9,
    very interesting, have to read it 3 to 4 times to understand your concept and the implications. It will take some time because of the different layess of my memories I have to dig into concerning experiences with transductor-technique, m786 is referring to, although you will not immidiately understand why I refer to this. If we develop ideas about how to tap the ZPE we need to know where the source is located. With matter involved , especially iron, it is the spontaneous magnetization which is the source we can tap. Right here the ZPE is pumping in energy every second, and I wonder why no one looks at this. I will fetch the basics and the data which I found in an old physics-textbook dated 1940. I did not find the number elsewhere.
    Go here : http://hyperphysics.phy-astr.gsu.edu/hbase/solids/ferro.html
    And the read the link about the “long range ordering”
    http://hyperphysics.phy-astr.gsu.edu/hbase/solids/ferro.html#c2
    Now we learn here that iron is a true magnetic-field-amplifier  ( > 5000 )
    Now you scroll down to the next paragraph : The Curie Temperature
    Starting from 0 degree Celsius the spontaneous magnetization disappears at 786 deg. Celsius
    Specific heat-capacity of iron : https://en.wikipedia.org/wiki/Heat_capacity
    0.450 Joule per gram or 450 Joule per kilogram
    So the energy of 1 kg of iron contained or better “hidden” in the spontaneous magnetization ( long range order)  at 786 deg.Celsius with reference to 0 deg. Celsius is 450 J x 786 = 218 780 Joule which equals Watt seconds. ( 218 780 / 1000 = 218 KW s
    With reference to = deg. Kelvin and  1041 K Curie-Temp  it is : 1041 x 450 = 468 450 Ws.
    Since this energy( in form of spontaneous magnetization)  is continuously existent every succeeding second in the flow of time, you can sum it up for 1 hour to 1,682 672 Million KWh .
    In order to simulate the fieldstrenght H present by spontaneous magnetizations we would need :
    1,5 x10⁷ Oe = 1,194 x 10 ⁹ A/m !!! , a value which we can not produce by technical means ( these numbers I got from my old physics textbook )
    Now the question is : Why are we not able to extract this energy present within a transformer ?
    Answer :  The energy we apply in a transformer is used to order the former unordered spontaneous magnetization only and upon releasing it we can only transfer what we have put into it in the first place. We do not tap the 468 450 Ws â€" Level, because after releasing our input the magnetic nucleus fall back on this level. Would we able to tap it the iron will cool down and recover its unordered state by tapping the ZPE.
    Now we have to think about how to tap this level. And it is here the magnetic amplifier-technique m786 ( funny why he is using the 786 Curie-Temp in his user name )  is speaking about comes into play.
    Now, the hunt is on.
    Kator01
arce
Inclined to believe that this is the phenomenon ... excitement .... electrons in a metal surface under the effect of HV field, must be something very simple .... that's why it's so hard to understand ... we're looking for something complicated....... instead  any great invention ... it's so simple in principle.
