John M
Quote from: forest on February 12, 2012, 11:55:09 AM
John
Where did you saw two grounds ?!!!!  :o
One ground was to a water pipe and the other was to a buried radiator in one of the videos (?). I don't know if that was always the case on other videos.
John
forest
Quote from: arce on February 12, 2012, 12:07:51 PM
Inclined to believe that this is the phenomenon ... excitement .... electrons in a metal surface under the effect of HV field, must be something very simple .... that's why it's so hard to understand ... we're looking for something complicated....... instead  any great invention ... it's so simple in principle.
ok, what is the simplest way to generate ac ? maybe magnet and coil and a movement or pulsing ?
recall various Tariel comments [size=78%]who is Melnichenko ,huh? what is the surrounding energy we are tapping everytime even with physical excersise , huh ?[/size]
forest
Quote from: John M on February 12, 2012, 12:17:45 PM
One ground was to a water pipe and the other was to a buried radiator. I don't know if that was always the case on other videos.
John
;D  You didn't watched "green box" video carefully ! Watch again with english subtitles or better with russian subtitles (more fully translated ) . You will find that burried radiator failed to light more then one bulb and ground connection was only one.
John M
Quote from: forest on February 12, 2012, 12:24:01 PM
forest-Thank you for the clarification. I think Wesley mentioned two grounds relating to his questions or theories about the Kapandze as quoted below.
"But he uses  a lot of load there. I recall  -faucet with cold water pipe  that is ground #1 and -radiator from old automobile deep in to the ground and water poured.   ground # 2 The distance between points of  ground is our conductor that should obey  superposition rule."
If he didn't have to use two grounds then we don't have to include even more theory to make it more complicated then it is.
John
arce
Much energy there ... the universe is more energy than matter ... even more people are composed of energy than matter .... and i think this year will be 2012 .... more .... changing.... the people will have access to other energy....... researchers neglected until now ... now is the time.
