0 Members and 28 Guests are viewing this topic.
frantz
Quote from: scratchrobot on February 15, 2012, 01:07:07 PM
Cosmo only answers questions about device?
You have right... ;-)
But if you know about which one device, I will be grateful for information... ;-)
Regards Body
Waves
Thanks Cosmo ,good shematics,  maybe i find some use for them.
cosmoLV
Description Of Inventions (Short Version) By Guntis Drevinskis / cosmoLV
Options for the Free Energy devices!
1.) Ferromagnetic Device: (Extracting Energy From Ferromagnetic Domains)
it is made based on Ferrite magnetic domains and not have any relationships with "eather" (Extra energy are produced by efficient spin of ferromagnetic domains)
HV voltage generator are made using HV source like Mini Tesla coil with adjustable core or any similar HV source, as generator can be used "Blocking Generator" with one transistor.
high voltage is applied Ñ,о the next coul throught sparkgap ar without it â€" and by adjusting frequency can be find the right one who release Magnetic domains â€" this effect can be seen by compass (this is first stage where you have static powerfull magnet.
Impulses from Blocking generator are directed to Frequency divider (it can be any IC) from your choice
* Due to frequency shifts produced in HV section - frequency divider always follows them and output will be in right matching between HV part and Low Voltage part
The output Transformer, but his is not a transformer - this is "choke" where input 220 volts are amplified by spanned domains!
Domain order are controlled with one IGBT or IGBT equivalent circuit like this one: (in attachment)
* Or can be used different transistor circuit (it's up to YOU) also everything can be updated and improved (like coil arrangement setup and winding improvements "from simple to complex") for increasing efficiency!
2.) Energy Device Using Natural Medium: (Extracting Energy From Natural Medium)
This Technique are completely different from above and little bit complex due to our Physics understandings, but are realised using phisics standards.
Also output transformer is not transformer but choke where High voltage are producing light ionisation second "inductor" produces light magnetic field who is produced by (sparkgap) No more than 2000 triggered volts in frequency of 50 Hz (or by your choice, for example 60Hz) By increasing frequency of sparkgap, or "can be replaced" with electronic sparkgap like (SIDAC), can be achieved different types and characteristics of magnetic field â€" Up to gravity effects (something about "one million interrupts per second")
* Due to two Potentials are produced second magnetic field â€" can be detected with any materials or compas (it has properties to attract any materials â€" also metallic, plastic, paper - e.t.c...) in one word like "Gravitational field" or electrostatic field - if you like call this that! But it is not only electrostatic - it is one of two together "like i say already" Ionised   Light magnetic field (both of them need to be realised from High Voltage)
3.) Others: (Using capacitors, in one word "Tesla Damped Wave")
Most easiest way, but not powerfull â€" be can be done
It is similar to Bedini device, but capacitors are divided in two parts, One part is charged for selffeeding other is to output, but both parts are with output controller with some "Mosfeet" controller who take charged capacitor energy and feed it to output coil (mostly to inverting transformer)
* This method is complex to build, but easy to understand with usual thinking.
This type of technology trying to realise many peoples: The best people in this area is Russian experimenter and enthusiast "Dynatron"
other are Don Smith, who also worked in this area but without success.
I wish to all good luck and wish to understand what I'm wrote â€" don't lose this post and keep the good work!
* Some parts are not explained for some reasons, but this is enough to make some conclusions and take step closer to final thoughts.
Best Wishes to all.
Keep your chakras opened :)
frantz
Quote from: Waves on February 15, 2012, 02:01:27 PM
Maybe inside some rockets... ;-)
forest
1  charge capacitor and discharge into special transformer  then collect etheric flow and via spark gap and laod dump to real ground
2 charge capacitor via displacement current from ground electrons via spark gap and load rhytmically
3 use ferromagnetic core with domains flip-flop at right angle
4 maintain resonance on primary ,secondary is copied by nature, choose resonant tank to limit current (parallel)
5 ionize air and collect ions to chage capacitor and dump to ground via load
6 convert electrostatic charge into slower oscilaltions and amplify current by pushin electrons out of some materials like iron or carbon or zinc or graphite or graphene
and so on and so on and combine
much respect to Vladimir Utkin, Kapanadze SR913, delamorto and others.
cosmoLV : are you sure you are inventor ?
