0 Members and 112 Guests are viewing this topic.
hartiberlin
hartiberlin
I am totally puzzled about  the mechanical overunity motor of Tariel Kapanadze.
In the German translation it is said, that it also used gravitation.
But I guess it just only uses the inertia of the 2 discs.
It is said, that the 2 disc are of steel and brass or maybe each disc is
a double layer of steel and brass and that these discs are connected via a brass wire, that is isolated from the steel shaft.
The toroidal transformer, that is put around  the shaft seems to be
the main motive power source and it is said in the "broken" Russian-German translation
that it uses just 8 Watts of power.
I am still totally puzzled, how this motor should really work...
I could only image that it uses some kind of eddy current torque drive effects on the shaft
so there might be a rotational field inside the toroidal transformer that might generate
eddy currents inside the shaft that will rotate the shaft...??
But I don´t understand how it is possible to generate such strong
torque forces to rotate the axis with these 2 heavy discs and then still propell
the car alternator and  still power this at least 100 Watts lights with it
and the only power used to start it is from a small 9 Volts battery !!!
Amazing !
This movie is from a new release from a Russian movie from youtube user Realstrannik
http://www.youtube.com/watch?v=vZC5CwCTv4I
As this movie was very long, I chopped it up in parts to make it easier to view.
Many thanks to the Russian Realstrannik forum admin for posting this video.
I posted it on my youtube channel
http://www.youtube.com/user/overunitydotcom/videos
as backup copies.
Regards, Stefan.
John M
Quote from: verpies on February 17, 2012, 08:49:37 AM
I just came back from a 3 week vacation.
What's new in this thread?
Any interesting devices worth replicating?
...by "interesting" I mean devices with reliably measured output power that is greater than the input power ...or any selfrunners.
Verpies - There has been a lot of posts regarding the use of iron wire, possibly used inside the copper tubing primary. It has been more focused on why the device works rather then just what to do to duplicate the Kapanadze device. Personally I hope it stays focused on why it works.
John
pix
Quote from: T-1000 on February 16, 2012, 05:16:45 PM
That was quick writing from my mobile device, sorry ;)
The http://en.wikipedia.org/wiki/Air_ioniser explains process.
The http://en.wikipedia.org/wiki/Secondary_emission effect is applied between charged capacitor plates inside of tube what got gas with lots of free electrons/ions characteristics (Hydrogen, Halogen, Argon, etc).
So basically it is quite similar to atomic chain reaction but just on  electrons/ions level.
Single ion from Cathode hits neutral one in gas and multiplied number of them arrive to Anode - so here is energy gain!
Fron Anode it goes to capacitor plate and gets discharged to load over spark gap..
There are many ways to Rome, and one of them I just exlained (hopefully) here... :)
Indeed. Simple spark gap is an energy multiplier. Read amperage AFTER the spark gap.In ambient air one ballstic electron emmitted from cathode during his way to anode (accelerated by an electric fied) liberates 10 exp7 electron-ion pars. Electrons are moving towards anode quicker than slow ions, so there is this extra charge separation.To avoid recombination a strong magnetic field is applied between spark gap electrodes.It is called electron avalanche and goes like nuclear chain reaction.
Regards,
pix
Another way is Philo Farnsworth multipactor, every photon multiplier works this way.
T-1000
Quote from: scratchrobot on February 17, 2012, 08:26:42 AM
Can you explain where the extra energy comes from?
http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA246207
To answer your question, first you need to find answer in others:
What is electricity?
What processes are in ionized gas?
What causes ions movement?
Where ion winds come from?
And the most important - Do we have same amount of ions in gas as they come out from negatively charged electrode?
Even in vacuum tube you can make condition what causes chain ion movement reaction(second emission), so can be applied to gas instead of vacuum?
And now from experiments data: we made second emission condition with Tesla Coil and 2 plates hanging in air and causing ion winds, then over thyraton we controled capacitive discharge and that caused ferrite of 700W impulse transformer to blow into pieces... So far so good, less than 10W to run Tesla coil and so much power out.
http://freeenergylt.narod2.ru/anonim_aidas_energy/
