0 Members and 58 Guests are viewing this topic.
verpies
Quote from: T-1000 on February 18, 2012, 04:26:34 PM
If there is same or less power out, how much power is needed to do same thing? Then you can ask the author of this video for measurements on how much power load takes when it is plugged in (not counting standby circuit consumption).
The caveat with this reasonong is the assumption that the "standby consumption" is constant.
For example with shunt regulated power supplies, the "standby consumption" is very high without an external load, yet it is very low when the load is connected.  The opposite to the intuitive expectation.
Thus judging the output power based on the difference between the input power with and without a load is extremely misleading if not impossible.
T-1000
Quote from: verpies on February 18, 2012, 05:58:55 PM
When you need to know how load affects input, you always measure Watts transfered not Watts wasted inside on system.
And in cases when standby running system consumes less than 50 watts and you apply hundreds of watts load, there is clear difference.
Then ultimatelly if you ever assemble OU system some day what will do exactly this, the last step is to feed back output power to intput... ;)
P.S> My meaning of "OU" is the power what comes from third party  outside of system what cannot be measured - particles from gas, earth, external magnetic fields and so on.
hartiberlin
Hi cosmoLV,
maybe you can tell us a vague function principle of this 2 disc motor ?
Where is the gravitational concept in this motor other than inertia of these heavy discs ?
I only see the "multiple" ? phase transformer being put over the steel axis and it might
guide the magnetic flux via the steel axis to the 2 discs . But how would these interact to this
flux input ? Also the isolated brass coil which connects the 2 disc is kind of
strange.
Will there be a voltage induced inside this coil due to the magnetic flux input from the axis  from the
multiple phase transformer driver and will this build up a LC circuit with the 2 discs somehow ?
Does it go into resonance somehow ?
But how does this affect the gravitation and would give some torque motion drive to the
steel axis ??
It is just amazing seeing Kapanadze use a small 9 Volts battery to propell this heavy drive system
and switch it into a selfrunning system powering additional Kwatts loads !
I think Kapanadze is really the new Tesla of the 21st century...
He should really apply this for the Nobel prize and go public with it, before all the miilitary
guys lock this away for their black projects...
Regards, Stefan.
Quote from: cosmoLV on February 17, 2012, 06:54:46 PM
The German speaks correct!
It uses Gravitational effects - you connot do this by usual magnetic field newer, or must be a super strong electromagnetic forces, but you will newer turn shaft in such way and so fast with so small "usual" electromagnet. (especieally form 9v battery) :)
But Gravitational force is much stronger - it can interact not only on metals! It have tremendous of power!
It has so much power that if you want you can split earth in two parts! Of course if you build large device like Tesla Tower - as i remember Tesla say this also, but it not say about gravity - at that time this will be to risky to say this!
Time will come very fast - too fast actually, but @All need to understand, that this is not a toy and newer will be a toy - in wrong hands this thing can make big and very bad things.
i experimented this with Rodin coil.
eh...... when this info comes out everybody will be amazed and science will shift about 100 years ahead of today's understandings about Physics! This is great, but we need time for such of technology! I'm not happy to say this, but i must say this with responsibility.
* (about ionisation - it also not be needed strong, enough usual tesla coil - ionised field has enough ions around)
hartiberlin
Quote from: samedsoft on February 17, 2012, 06:38:10 AM
Hi Stefan,
This not a replika this is one of the machines that Kapanadze built in Turkey for Zorlu Holding. They have sponsored him to build 8 machines..
  The guy on the end of the video is my friend and telling about the input and output of the system.
  Nuri..
Hi Nuri,
many thanks for this info.
Cpuld you please translate exactly, what this guy says at the mid to the end of the video ?
What does he say about the Milliamps input ?
Also I can see here no running sparkgaps with these big Teslacoils .
In the other blue colored Teslacoils demo video inside the shielded room
there were arcs running in about 5 to 10 cm lengths, but in this video you see no arcs
running, at least not, when he zooms up a bit to the coils...
So please let us know more about your friend and his involvement  with the Kapanadze devices and the
tests they have done.
Here is an info about the Zorlo group.
http://www.zorlu.com/EN/ZORLU/default.asp
Seems to be a pretty big company.
Regards, Stefan.
