0 Members and 581 Guests are viewing this topic.
hartiberlin
The big question is also, if the brass and steel disc are electrically still connected to the asix steel shaft
or not.
Let us assume that the magnetic A-Field is inducing a changing B-field inside the brass coil, so that it wll get an AC
voltage. So this AC voltage is then fed onto the brass and steel disc, but what now ?
How does this voltage get shorted to produce any flowing current so the current can cause any torque forces ?
Where is the B-Field to repell these forces so it gets a rotational force ??
Very strange...
Regards, Stefan.
dllabarre
Quote from: hartiberlin on February 19, 2012, 12:35:07 AM
In the German translation it is also said,
that the white foam coating is only there to reduce the noise...
Regards, Stefan.
Where can I see/hear the translation?
Thank you,
DonL
hartiberlin
Quote from: dllabarre on February 19, 2012, 01:22:33 AM
Thank you,
DonL
In this video there is the pretty bad Russian-German translation explanation as the audio source:
http://www.youtube.com/watch?v=3thvqFhFIfY
The girl made some errors:
at minute 7:50 she says:
the input current shows -1 milliamp,
But this is only the out of range display...
The meter is set there to a  mikroamps range and this it is out of range.
as it probably draws a few huindred or at least a few tens of milliamps during
startup...
I have a simular meter myself with these settings...
The 9 Volt battery has to power all these circuit boards there being shown...
but probably there they also have already the special power amplifying Kapanadze coil
inside the metal box there, so the battery only has to deliver low power.
Regards,. Stefan.
hartiberlin
In this video
http://www.youtube.com/watch?v=qVUN3GsekKQ
at 11:12 you can see, that in the box is already
the power amplification circuit as he has only
connected as the outpt the light bulbs panel and
he can light up all these bulbs with just the input of his small 9 Volts battery.
Amazing COP factor !
Regards, Stefan.
lazzythinker
Hi to everybody i'm new in this topic.I watch a video of Mr.Kapanadze motor and what i conclude
that in beetwen of two rotors in my opinion is just a spring around of axle and probably one of the rotor is not tied to the axle that's why squeking sound on start.Again i'm new and this is only my opinion.Hoppe this will help.
P.S.For another device i mean solid state,again this is only opinion,this will be a little insane but most of this device reasemling B/W tv except that output transformer.Especially 12v B/W TV.
Many of us will ask how.Does tv has frequenzies(adjustable freq.horizontal,vert etc.)i mean that wires which goes on yoke coil. It has it's own frequencies generator.Again this is only my opinion.
