0 Members and 523 Guests are viewing this topic.
cosmoLV
Quote from: hartiberlin on February 19, 2012, 12:52:40 AM
The big question is also, if the brass and steel disc are electrically still connected to the asix steel shaft
or not.
Let us assume that the magnetic A-Field is inducing a changing B-field inside the brass coil, so that it wll get an AC
voltage. So this AC voltage is then fed onto the brass and steel disc, but what now ?
How does this voltage get shorted to produce any flowing current so the current can cause any torque forces ?
Where is the B-Field to repell these forces so it gets a rotational force ??
Very strange...
Regards, Stefan.
Torque force are not caused by currents in this device - it is caused by Gravitational field - there is one thing "You will look, but don't see or understand"
* There is not going currents to these discs, but impulses.
How it is working:
Impulses from toroid transformer are distributed to metal shaft, Little coil between both discs catch these impulses and provide it to both discs.
BUT - before these electric pulses are going to toroid transformer (they are produced in certain way - that they already have Gravitational effect. these electric impulses are not ordinary pulses who have usual magnetic characteristics!
i like to repeat - don't try to find answers in physics books.
Keep your chakras opened :)
bolt
The last TEN posts or so are BLIND to the elephant in the room! ONLY Stefan noticed the extra power is already coming from the metal box and is able to light the lamps WITHOUT the motor!!
SO why are you trying to work out how the motor works its really not important and most likely NOT OU. Effective yes perhaps but not OU otherwise no need for the "secret box"  I say its just efficient  ok fine but any standard 3 phase motor working in Rotoverter mode here can be a 99.999% efficient  driver. Just clean the bearings, take off the fan and a 5 HP motor motor will run on just 2 watts at full speed!
You may ask why bother with this motor gen config?
1) its looks pretty for investors
2) it shows off his unique motor build prototype (NOT IMPORTANT ONLY A DISTRACTION)
3) it allows for a SMOOTH AC power source from the generator
4) it converts single phase rough supply from kapanadze solid state technology normally only can light lamps to ultra pure sine clean 3 phase using a 3 phase motor as a generator for powering 3 phase factory motors and equipment!
So fast forward to where he builds the early solid state kapanadze and THERE is the answer.
phoneboy
Just a thought. I believe that the Discs are the main propulsion source, but if the coil is inducing current into the metal shaft then the current would also be flowing through those large pillow block bearings (ball bearings) which could also cause rotation.
stivep
For the purpose of  analysis only:
1. lets assume that 9v battery is operating only with diode connected in series
2.lets assume that big box  has bank of car batteries inside
3. lets assume that when  TK connects right polarity  rely is operated with it only switching on  internal bank of batters and because of  mechanical squick you can not notice the click But you have rapid motion as if high current is rapidly connected.
4.lets assume that when he reverse voltage than HE ACTIVATE electronic rely
5.That  allow him without the noise of rely to switch inverter to operate light bulb without the motor that is only to amuse you folks.
minute 10:59 TK operates lightbulbs without the motor.
http://www.youtube.com/watch?v=qVUN3GsekKQ
DO NOT CONFUSE YOURSELF WITH TWO VIDEOS THAT LOOKS SIMILAR.
THE MAJOR DIFFERENCE IS THAT THE ONE WITH BIG ELECTRICAL MOTOR HAS BIG BOX
AND THE ONE FROM GERMAN TV HAS VERY SHALLOW BUT LONG BASE THAT COULD EASILY FIT BANK OF BATERIES MADE FOR ALARM INDUSTRY  12v/8ah SAY 40 OF THEM
http://www.ebay.com/itm/UB12100-S-
12V-10Ah-Home-Alarm-Security-System-Battery-/120587500618?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu
%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%
26pmod%3D360420007571%26ps%3D54
some of them are 12V/ 10AH
6. lets concentrate at German part of video showing  Teflon housing mounted and toroid  placed inside. minute 3:47
http://www.youtube.com/watch?v=3thvqFhFIfY
7. try to find out how is winded. Count  how many wires are connected to plastic connector and what part of winding on toroid that wires are coming from
8. in both of the videos rotation mechanism based on magnetic flux was done differently
8a. look at the  elevated supports of the brackets
notice that inner part  facing discs might be not made from metal ( covered  with foam)
at video
9. from that  work  further .
Read that in Wikipedia link says no big voltage needed for  operation of this  type of disc-motor.
http://en.wikipedia.org/wiki/Homopolar_generator
Original patent of Tesla
http://www.google.com/patents?id=MvdbAAAAEBAJ&pg=PA1&dq=406968&source=gbs_selected_pages&cad=2#v=onepage&q=406968&f=true
I do apologize that I made it so quick.
I'm in the middle of scientific session.
Wesley
So WHAT IS THE PURPOSE OF THE FOAM? ??? ??? ??? ???
TO COVER ACCESS DOORS TO COMPARTMENTS
ALSO TO SHOW THAT PART OF FLOOR UNDERNEATH OF COILS IS NOT MADE FROM METAL ALLOWING MAGNETIC FLUX TO PENETRATE
Ok I have got it... when meter was connected to toroid it shows 0V
Two options:
a. this toroid did nothing
b. this toroid was sensing small magnet embedded  to shaft to coordinate pusles by reading only
CONCLUSION:
TARIEL KAPANADZE IS NOT LIAR.
HE HAD AT THAT STAGE OF HIS LIFE AND DEVELOPMENT  NOTHING MORE BUT DONALD SMITH DEVICE...that device was further advanced and perfected till the point of show of Turkey
garrypm
Anyone else make out the distinct hum at 27:05 in the full video where tk coonects
the battery without motor or panel of lights connected.
50 or 60 Hz like the hum from a large transformer.
Garry
