0 Members and 929 Guests are viewing this topic.
baroutologos
I have been experimenting in some Bulgarian setups concerning Kapanadze device and then it hit me a long made observation that i have done concerning those setups and may actually prove that this replication maybe fake.
I explain.
I have tried to replicate Tesla's patent of electrical conversion and distribution. I have seen long time now that the produced currents of a capacitor discharging in a coil and having a load are of considerable frequency or bear hypertones etc making  DMM having a diffuclt time of reading them.
Actually in my experimental carreer no DMM i have bought can read them. In the video of replication we have seen, Teofillus DMM have not hard time and read them accurately hence we conlcuded that 228volts *2.03amps = 462 watts. (and seeing bulbs' brightness)
In case Teofillus DMMs' are of high quality and outstanding ability of reading high frequency currents, then they should not read them at all.
Mine cannot read them, no matter how i configure my setup.
Of course it can be said that resonance is tuned at 50Hz or even 400Hz that most DMM can measure. But, with components shown and those aircoils resonance - if any - should go well into Khz range. ( that most DMM cannot read)
So, a wire underneath the cloth from a mains outlet is a very good explanation to me now.
By the way i urge anyone with a finest quality DMM (not o-scope) to try measure a cap-discharging to coil-load currents and voltage.
Omnibus
@baroutologos,
It has been explained more than once that for these measurements, involving signals of complex form, one should only use oscilloscopes, possibly high end ones. Since the most important characteristics are the input and the output energy one should approach these measurements with utmost care. To evaluate properly the energy in and out one should measure the momentary values of current and voltage at highest possible digitization resolution (to be able to account for the fine structure of the signal), multiply these momentary I and V values and integrate them over time. Anything else, including using lamps, can be considered qualitative assessment, at best, and many times that can be quite misleading. Most of the problems in this area are due to measurement errors and that's the main reason we're at a stalemate with this at this time.
xenomorphlabs
Kapanadze is measuring with very cheap DMMs the voltage too in the outdoor demonstration.
That opens room for more speculation. Maybe he managed to exclude
high frequency signals from the output coil.
Since nobody REALLY knows what Kapanadze is doing there, everything is possible.
Maybe the signal generated in that coil is low-pass filtered.
In the aquarium demo you can clearly hear a 200 Hz magnetostriction transformer ringing.
If a replicator wants to be sure, he should use oscilloscopes and advanced measurements, but none of the replicators has clearly stated any OU claims.
It is just preliminary experiments as it appears to me.
By the way, there is no real proof that it is actually Teofillus who made that deleted video. So i think folks should be careful to conclude that he is the same guy like replicator1969. Just the fact that they both have the same DMM sais NOTHING.
The guys probably simply shop in the same electronics shop which might have a limited selection of DMMs and other equipment, this is Bulgaria after all.
grizli
Quote from: baroutologos on March 29, 2010, 01:22:04 PM
But actually it does not matter hmm
Have you seen that schematics , mad posted it when secondary of TC is seriws with 220V output from inverter..
maybe thats the reason why meter reads current
grizli
Quote from: Omnibus on March 29, 2010, 01:42:02 PM
@baroutologos,
you just need battery, and stopwatch hehe .. heat and light on the bulbs is obvious if there is much OU....
on the video WE CAN actually see that battery current did not drop hmm ...
2,5 mins for 5aH battery driving 500W bulbs ..
No scope is not good measure here...  actually what if "kind" of different electricity can not be measured classal way, just effects canbe seen
known capacity battery, stop watch, and heater with calorimeter.. if ou is small
