0 Members and 903 Guests are viewing this topic.
Omnibus
Quote from: grizli on March 29, 2010, 03:00:24 PM
you just need battery, and stopwatch hehe .. heat and light on the bulbs is obvious if there is much OU....
on the video WE CAN actually see that battery current did not drop hmm ...
2,5 mins for 5aH battery driving 500W bulbs ..
No scope is not good measure here...  actually what if "kind" of different electricity can not be measured classal way, just effects canbe seen
known capacity battery, stop watch, and heater with calorimeter.. if ou is small
Well. if that's a self-sustaining device, of course, just caps would be OK. However, remember how Don Smith declined to answer clearly if the battery can be replaced by caps. There's something fundamentally fishy here. As for "different electricity that can't be measured the classical way", forget it. There's no such thing. Calorimetry also, if the OU effect is small calorimetry won't be sensitive enough. Bulbs -- unreliable because their resistance changes dramatically. Dimmer lamps can consume higher power than brighter ones let alone certain types which are of very low power consumption and still shine brightly. No, bulbs can be misleading. There are known, well developed and understood ways of measuring energy of these devices and we shouldn't try to re-invent the wheel in these elementary things.
Omnibus
Quote from: xenomorphlabs on March 29, 2010, 02:01:45 PM
Kapanadze is measuring with very cheap DMMs the voltage too in the outdoor demonstration.
That opens room for more speculation. Maybe he managed to exclude
high frequency signals from the output coil.
Since nobody REALLY knows what Kapanadze is doing there, everything is possible.
Maybe the signal generated in that coil is low-pass filtered.
In the aquarium demo you can clearly hear a 200 Hz magnetostriction transformer ringing.
If a replicator wants to be sure, he should use oscilloscopes and advanced measurements, but none of the replicators has clearly stated any OU claims.
It is just preliminary experiments as it appears to me.
By the way, there is no real proof that it is actually Teofillus who made that deleted video. So i think folks should be careful to conclude that he is the same guy like replicator1969. Just the fact that they both have the same DMM sais NOTHING.
The guys probably simply shop in the same electronics shop which might have a limited selection of DMMs and other equipment, this is Bulgaria after all.
Actually, it appears that the deleted video was indeed by @teofiliuss -- cf. here http://mazeto.net/index.php?topic=4454.msg20998;topicseen#msg20998
forest
Batteries cannot be replaced with capacitors because :
1. Don systems run from inverters
2. It require initial energy input
3. Capacitors are  too fast in discharging.
Maybe it's possible to repalce batteries with large capacitors if they could put large amperage peaks but a few times not just once.
Omnibus
Quote from: forest on March 29, 2010, 04:08:17 PM
Even easier would be to carry out correct energy measurements with an oscilloscope of Ein and Eout and compare these quantities. Like I said, self-sustaining would be OK and can replace such easy measurements but achieving it convincingly is quite complicated. More complicated that doing those well-understood elementary measurements. Why Ivanov, Smith, Kapanadze etc. don't do those measurements and resort to obfuscation is anyone's guess.
grizli
http://next-energy.ru/forum/index.php?topic=40.msg2372#msg2372
USER "SR"
CLAIMS
He knows how kapapadze works and is willing to share to people who "earn" that in matter of speaking
I DONT know russian, but we for sure have some people who know.. let them contact user SR there
Yes but SR starts to brag :D
He he human psychology is more fascinating than free energy itself :D:D:D
REad to forum through goole translator..
heheit becomes really interesting:
SEEMS its not hard to dicover "free energy"(many people did ) its much harder to purge your own egoism hehe :D
