0 Members and 1888 Guests are viewing this topic.
firlight
Quote from: jbignes5 on February 25, 2012, 06:05:34 PM
Ok science has always been masterbation. Care to explain why we can not find the electron? It's so nice to see people believe in something they never saw.. SCIENCE believes in fairies like the electron.
  Ooop`s They have found some.http://www.bbc.co.uk/news/science-environment-17156036
Dave :)
bolt
Quote from: FreeEnergyInfo on February 26, 2012, 06:12:26 PM
MUSTAFA 007 FREE ENERGY ...
IN = 250 W   OUT = 6 KW  !!!!!!!
www.freeenergylt.narod2.ru/mustafa007/
FORUM ....
MUSTAFA 007 FREE ENERGY ... 250 IN = W OUT = 6 KW!!!!!!! www.freeenergylt.narod2.ru/mustafa007/ FORUM .... www.realstrannik.ru/forum/39-kapanadze/47235 -rabochaya-sxema-generatora-kapanadze.html not resist! I decided to write about. I understand the principle of solar cell generators. Conducted a successful experiment, based on my findings and the latest video Kapanadze I drew a diagram. declare the scheme 100% working. At the output of 50 Hz with a filling frequency of the generator, which can be easily removed using the choke and capacitor, then the output is a pure sine.  base unit:  1) Create a resonance in the LC circuit. In the circuit there is reactive power.  2) Remove the reactive power without affecting the resonant circuit.  connection, as shown in the diagram allows you to remove the reactive power to the circuit without affecting the parameters of the serial LC circuit. When properly selected parameters of the coils and matching transformer at the output has an output up to 10 kW. Neither the direction of winding, no way of winding in no way affect the parameters.  Important to a current transformer:  1) the primary coil is no more than one turn. Best version 0.5 turns.  2) current transformer to do on the ferrite  3) the overall mass should correspond to the reactive power in the circuit.  Important to the LC circuit:  1) the best result. Reactance of the capacitance at the operating frequency must be equal to the reactance of inductance on the same frequency.  2) Inductance is best done in the air, so you can achieve more reactive power.  3) The currents in this circuit sooo big lead to take not less than 4 mm can be more  4) the capacity to do the composite. If you for example need 2 uF it must be composed of 20 pieces of 0.1 uF. This is done for the distribution of flowing currents.  Anything else you see in the video is tinsel. BB unnecessary, the inductor is unnecessary. Also enclose a drawing which shows a device with a transformer Kapanadze. I recommend not to do so, because such an arrangement of coils reduces the output power. Above a certain power is changing the magnetic permeability, and the circuit upset. This is for inquisitive minds drift.  Circuitry I have another. test version input 250W output of 6kW. It depicted a diagram of the video Kapanadze.Consider the temporal characteristics of the serial LC circuit. At resonance, the current lags the voltage by 90 degrees. I use a current transformer overcurrent sostovlyaet, so I am submitting changes to the circuit, even at full load current of the transformer. While working there, when the load is compensated inductors (in other words not picked up) circuit adjusts itself without letting go of the resonant frequency. For example, the coil turns in the air, six 6mm copper tube 2 diameter of 100 mm frame, and the capacitance of 3 pF is resonant frequency of approximately 60 kHz. In this circuit can be accelerated up to 20 kW reagent. Accordingly, the current trans should have overall capacity of not less than 20 kW. You can use anything. Ring - fine, but when such facilities more likely withdrawal of the core into saturation, so we need to introduce a gap in the core, and this is the easiest way with ferrites on TVSA. At this frequency, a core is able to dissipate about 500 watts, so it is necessary 20 000 \ 500 is not less than 40 cores. important condition - to create a resonant LC circuit in series. The processes occurring in such a resonance is well described. An important element - a current transformer. Its inductance should be less than one tenth circuit inductance. If there are, the resonance will fall apart. It should also take into account the transformation coefficients, and the matching of the current transformers. The first is calculated from the impedance of the generator and the oscillator circuit. The second depends on the voltage developed in the circuit. In the previous example, the circuit 6 turns the voltage developed at 300 volts. It turns on the coil of 50 volts. Current trans uses 0.5 turns, then the primary will be in his 25 volts, so secondary housing must contain 10 turns to reach the voltage of 250 volts at the output. Everything else Yes, in principle, and is calculated according to classical schemes.  How will you initiate the contour does not matter . An important part - is a matching trans, an oscillating circuit, and current trans for the removal of the reagent. If you want this effect to realize the TT. You need to know and have experience in building high-frequency circuits. In the TT with 1/4 wave resonance, as is the separation of current and the voltage by 90 degrees. On top of tension, the bottom current. If you spend an analogy with the submitted scheme and TT, you will see the similarity, both pumping and removal occurs on the side of the current component. Similarly, the device works, and Smith. So do not recommend starting with CT or Smith not being experienced. But this device can literally build on the knee, while having only one tester. How to post in one of said lazj "... Kapanadze oscilloscope because of the angle seen ..." Thus there is a modulation of the carrier. But such a decision - after all transistors with single shock can work. If they did not submit the rectified, it will be only one half wave. modulation is needed in order so you do not suffer with the transformation of 50 HZ standard ... For the output of the sine of 50 Hz. Without it, then it will be possible to feed only a resistive load (light bulbs, heating spirals ...).The engine, or a transformer at 50 Hz will not work without this modulation. master oscillator I outlined rectangle. It provides a stable frequency at which the LC circuit resonates. Pulsating voltage change (sine) is served only on weekends keys. The resonance of the tuned circuit will not bounced just in time kzhdy in the loop to spin more or less power to the beat of the sinus. It's as if the swing talkan, with greater or lesser degree, the resonance of the swing does not change, only the energy.resonance free vibrations can disrupt just load it directly, because changing the parameters of the contour. In this scheme, the load does not affect the parameters of the circuit, it is self-tuning. Impacting the current transformer, on the one hand changing the parameters of the circuit and the other is changing the permeability of the transformer core, umenshaya its inductance. Thus for the circuit load "not visible". And the contour of the free vibrations of a committed and continues to commit. By varying the voltage of keys (modulation), the only change amlituda free vibration and all. If you have an oscilloscope and generator, perform an experiment to serve on the generator circuit resonance frequency of the circuit, then change the amplitude of the input signal. And see that there is no breakdown. Yes, the matching transformer and current transformer based on ferrite, air resonant circuit. The more it turns the higher the quality factor, on one side. On the other higher the resistance, which reduces the ultimate capacity, because the main power goes into heating the circuit. Therefore, you should seek a compromise. With regard to merit. Even with Q 10 at 100 W input power of 1,000 kW will reagent. Of these, 900 W can be removed. It is perfectly attuned with the conditions. In the real world from 0.6-0.7 reagent.But it's all little things, in comparison with the fact that we should not bury the radiator and steam from the earth! And it even had Cape Island broke ground on the device! And it turns out not nada!  Revktiv rushing and without working zazemleniya.Eto bezsporno.A here with removable current transformer, will have to mess ... Not all prosto.Obratnoe imeetsya.Stepanov effect once it is decided in the patent from him out there for this purpose diodes are drawn . Although the presence of the diodes have Stepanova each interprets differently. This option can only be set to 50 Hz resonant frequency. Since the circuit spinning high currents, respectively, the diodes are needed for strong current. For these diodes do not kHz. With vibrant trance, in a magazine article met scoop "diode circuit," or something like that. There should be the same inductance as a consequence the number of turns.
Amazing when i   described the exact workings  on here over 5 years ago and now is being repeated almost word for word.  Kapandze tech is  a VARS device of around 50 kVARS and the extraction at 10% provides 5kw o/p.  He uses 2 off  COP 10 stages to provide COP of 100.   The TPU is a 3 phase device of VERY similar technology of 10 kVAR's for 1000 W o/p.  Kapandze uses low Khz VARS tank and 50hz modulation. The TPU uses High Khz to low Mhz VARS tank and 5khz modulator.  TPU is a 3 dimensional 3 phase device 10*10*10= COP 1000
jbignes5
Quote from: firlight on February 26, 2012, 07:18:45 PM
Dave :)
Umm no thats a charged atom and not the electron. Plus what we have there is matrixing. This means that what you are seeing is made up in your head when you view it. There is no real time motion there is nothing but as snapshot. Sop pixelated and unable to understand it from a single slide view and thats your proof of the electron or what they are telling you the electron is???.
To me it looks like 4 blobs with not much to see but grainy pixels. No motion to it to see if they are moving or anything. Anyways I thought the "electron was revolving around the atom from their definition.
Until we get real evidence that picture could be anything at all. Like I said masterbation at best..
IWD
Dave :)
well, I do not know how much scientist you have met, but normaly they are people, for which are no one doctrine absolute, and always searching for another answers.
That reminds me, not so far ago there was big uproar about "the trumped signal" now its gone?
I was trying to explore it and, it seems it is just simply periodicaly interrupted resonant rise, nurtured from source.
discharge of capacitor conected to AV plug just create wave with  different speed of movement,(frequency)
so..it can be done without cadauces, any coil will serve to show "trumpet".
but still it is interesting way how to use some extra charges harvested from LC tank
Kaduci
I WANT TO THANK GREAT MAN STIVEN MARK AND ALSO OTTO SABLARIC FOR THEIR GREAT JOB AND ALL KIND OF FREE INFORMATIONS ABOUT TPU.
YOU SHOULD TO KNOW THAT NEW-OVER-UNITY NOU-REVOLUTION WAS STARTED IN 2012 IN RUSSIA, NOW IT'S TIME TO BE SPREADING OVER THE WHOLE PLANET !!
FREE IDEAS, FREE DATA, AND FREE ENERGY, FOR ALL PEOPLE WHICH WANT TO BE FREE !! THIS IS SOME KIND OF GOOD SLOGAN FOR 21 CENTURY !!
THIS IS JUST FOR BEGINING.
TPU KEB - WORKING REPLICATION OF STIVEN MARK-OTTO !!
http://www.youtube.com/watch?v=FVMpoRhZLnA
THIS IS THE FIRST PART OF VIDEO - FREE DOWNLOAD
http://narod.ru/disk/41922027001.ae5720defe060437393a7c97d343e6ed/tpu-otto_1.flv.html
THIS IS A SECOND PART OF VIDEO - FREE DOWNLOAD
http://narod.ru/disk/42010295001.d6a5e0a2d75b0e2938b100a68d085654/ptu-otto2.AVI.html
IN NEXT DAYS WILL COME MORE GREAT VIDEOS AND GREAT INFORMATIONS !!
SHARE TO ALL FRIENDS THIS INFORMATIONS AND ALL IF YOU ARE WELCOME TO INTERNATIONL SITE REALSTRANNIK.RU
HERE YOU CAN LOG IN AND ASK QUESTIONS ON ENGLISH OR OTHER LANGUAGE IF YOU DON'T SPEAK RUSSIAN. ASK QUESTIONS TO USERS INOGDA1 AND KEB FOR A FIRST TIME !!
http://realstrannik.ru/forum/29-tpu/267-tpu.html
THANKS !!
