0 Members and 91 Guests are viewing this topic.
Kaduci
i can't insert video coz there is no video gadget and i gave problems to upload pictures in jpeg. Some SS (secret services) do a dirty job !!
WELL NEVER MIND IT'S 21 CENTURY AND THE TIME IS FOR FREE ENERGY !!
YOU ARE ALL WELCOME TO INTERNATIONAL FORUM OF FREE CE OR FREE OU RESEARCHERS !!
http://realstrannik.ru
TPU TOPIC IS HERE
http://realstrannik.ru/forum/29-tpu/267-tpu.html
СЕ или сверÑ... единица - mean OU overunity
WARNING:IF YOU CAN'T CONNECT TO OUR SITE REALSTRANNIK.RU YOU SHOULD TO KNOW THAT WE ARE UNDER MASSIVE NAZI DDOS - DENIAL-OF-SERVISE ATTACK !!
AFTER SOME TIME TRY NEW CONNECTION !!
firlight
Quote from: jbignes5 on February 26, 2012, 10:18:14 PM
Umm no thats a charged atom and not the electron. Plus what we have there is matrixing. This means that what you are seeing is made up in your head when you view it. There is no real time motion there is nothing but as snapshot. Sop pixelated and unable to understand it from a single slide view and thats your proof of the electron or what they are telling you the electron is???.
To me it looks like 4 blobs with not much to see but grainy pixels. No motion to it to see if they are moving or anything. Anyways I thought the "electron was revolving around the atom from their definition.
Until we get real evidence that picture could be anything at all. Like I said masterbation at best..
   You wont get any real evidence because it is all a head trip,you could say it is all a Hologram,or there is only
     one event we call a electron when we try to observe It pops out of the virtual space when we participation
   in trying to make measurements. So what it does not matter what we call it we can make tools .If it appears
    to exist and we can use it why not. What are these dots, you are observing on your screen."........"Coconuts ?
      Dave :)
dole
Hi,
This is very close to ferrite - nail coil experiment. I was very convinced at that time that this must be what Tariel is actually doing.
Output of the primary was around 5kHz and one thing is for certain that output do not disturb input, in this case would be the resonance in an primary.
What I found also is that output frequency change with geometry and number of turns. Interesting is that nail (rod) produced very low frequency compering to 5kHz input primary.
I tried mixing output with DC but not with AC. I concluded the same as @baroutologos at that time, that efficiently of the transformer was very low
but no one did try optimizing resonance and feedback to primary capacitor.
One thing I may mention, I tried to enlarge the setup with much bigger properties but to my surprise such conversing did not work at all. Who knows, two steps back and try again.
d.
firlight
Quote from: IWD on February 26, 2012, 10:32:31 PM
well, I do not know how much scientist you have met, but normaly they are people, for which are no one doctrine absolute, and always searching for another answers.
That reminds me, not so far ago there was big uproar about "the trumped signal" now its gone?
I was trying to explore it and, it seems it is just simply periodicaly interrupted resonant rise, nurtured from source.
discharge of capacitor conected to AV plug just create wave with  different speed of movement,
(frequency)
so..it can be done without cadauces, any coil will serve to show "trumpet".
but still it is interesting way how to use some extra charges harvested from LC tank
  I worked with more scientists around the world than I care to remember,as a engineer some I will
  go along with there model some I wont .The proof of the pudding is in the eating.It depends on
   What you want to construct.
  With regards to your trumpet wave I don`t see what the big deal is .The ring down and ring up
  waveforms are quite normal in inductively couple coils.Maybe its magic for those not practice`s
   in the art.
   You should try building a Blumlein Coax line transformer if you are interested in energy transfer.
    Remember the energy of the current travels through the insulation not the conductors ,what we
    call conductors are really obstructers.
Dave :)
jbignes5
 I guess my point was two things.
A: they are employed by IBM so they are not scientists with free thinking there. They get paid to work on what IBM wants them to work on.
B: It could be anything we are seeing there. There is not enough resolution to see anything definitively. So they matrix what they are seeing to match what they were looking for. It's a very common mistake. Our limited sight is only as good as the devices we create to enhance the sight.
  Now to get back to the real meat.
I was perusing the net and found something interesting that might help understand what others have done.
http://underservice.org/files/magnetic_amplifiers.pdf
I started looking at this from another experimenter who tossed the link up on another forum. So we have a catcher that can cause current to move from tip to ground. what if we use the magnetic amplifier to control that movement. Totally solid state non moving would last a long time don't you think? It could be self adjusting through feed back biasing of the catcher to match the load requirements.
Somehow there should be a way to take away the grid and replace it with a battery or set of batteries that could be auto swapped in and out to power the unit/recharge the batteries. The amount of flow would most likely be based on construction of the catcher.
Stevep how does that sound?
Yes it would still need a battery or set of batteries but think about it for a few...
This way we get rid of all the hokus pocus that seems to come out from the wood work and separates the unit from a flowing supply.
