0 Members and 52 Guests are viewing this topic.
andrea76
Quote from: 27Bubba on February 19, 2012, 07:48:45 AM
Please don't laugh.. Is it possible the brass disc have imbedded natural magnets, when coupled with the doughnut coil, it would make the rotors spin.. :D ;) I also think the brass disk is insulated from the shaft.
my 2¢
the magnet is under the small plate around the ball bearing at min 00:45 ofhttp://www.youtube.com/watch?v=3thvqFhFIfY
nord around the first and south on the other.when the beat of the mixing frequency travel on the shaft it collecting energy from environment.see the first hendershot motor (work only when is pointed in N/S direction)
enron-r-crooks
Have a look at this blocking oscillator circuit by Sergdo. If someone could translate this from Russian it would be tremendous.
http://www.youtube.com/watch?v=ILBHOrTOe8A
биÑ,,илярные высоковольÑ,ные каÑ,ушки, две шÑ,уки подключенный последоваÑ,ельно вÑ,оричным обмоÑ,ками и параллельно первичными, первичные включены по сÑ...еме блокинг генераÑ,ора. Лампа показанная в эксперименÑ,е использовалась с удалÑ'нной ниÑ,ью накала, мощносÑ,ÑŒ лампы была до удаления ниÑ,и накала 150 ваÑ,Ñ, 220 вольÑ,.
PS
Изредка ( в начале видео ) выбиваеÑ, блок пиÑ,ания Ñ,ак как ШИМ всÑ,роенный в сей не побоюсь сказаÑ,ÑŒ "грÑ'банный девайс", почему Ñ,о вмесÑ,о заявленной паспорÑ,ной мощносÑ,и 30 ваÑ,Ñ, выдаÑ'Ñ, всего 19 --- 20 ваÑ,Ñ,. Ð'оÑ, именно Ñ,ак киÑ,айцы и обманываюÑ, славянскоие народносÑ,и - на мощносÑ,и .. :-)
Translates from google
Bifilar coil high, two pieces connected in series and parallel to the secondary windings of the primary, the primary blocking scheme enabled by the generator. The lamp shown in the experiment used a remote filament lamp power was to remove the filament 150 watt 220 volt.
PS
Occasionally (at the beginning of the video) knocks out the power supply as the PWM built into this I am not afraid to say "fucking device," Why then instead of the stated power rating of 30 watts produces 19 --- 20 watts. That is exactly the Chinese nation and deceive slavyanskoie - on power .. :-)
http://www.youtube.com/watch?v=wXWtyqttPgk
More here
http://www.overunity.com/11761/very-high-and-powerful-voltazh-voltage-from-a-small-voltage/new/#new
read tekst infa
https://sites.google.com/site/dobrojanskij/soobseniebezzagolovka-2
https://lh4.googleusercontent.com/-FCNnk-yAzq8/ToAEwp4wF5I/AAAAAAAAAUE/KdSa6dTq8G8/s640/sxemakachalki.jpg
https://lh6.googleusercontent.com/-V6TgA9qrv1o/TsikCEEiq1I/AAAAAAAAAaU/i5rBfC2JOZ4/s720/bifmagus.jpg
https://lh4.googleusercontent.com/-z5YSx67l12M/TfII3IlLX5I/AAAAAAAAAMk/tFrcBEaytWw/s720/iptpn.jpg
wattsup
@all
Just got back from a week vacation so trying to catch up but in the following TK video.....
Tariel Kapanadze overunity motor 02 free energy located here....
http://www.youtube.com/watch?v=qVUN3GsekKQ&feature=relmfu
in my opinion is a bad fake.
First, the bearings holding the wheel on each side can easily consist of a bearing plus a hidden pulley wheel. The whole "bearing assembly", shaft and wheel is mounted on this thick stock aluminum blocks that can have a inner channel for the pulley belt to go from the pulley wheel to under the wheel and into that steel box. This is all junk trick, I am sorry to say. Otherwise why make that steel box under the dual flywheel.
Such a bearing has no reason to have such large bearing holders with screwed on side plate when there are so many standard bearings and  holders available that can be used in 5 minutes. Why goto all the trouble of custom building such a bearing assembly? NO REASON AT ALL BUT TO TRICK.
Second, there is no way possible for that rinkie dinkie shaft coil to make that wheel turn even one rotation let alone to then turn it against that generator. PLus, when the guy was measuring the shaft coil voltage when the wheel was turning it showed 0 volts.
This is very disappointing to see those guys trying to show off this mechanical thing and try to pass it off as an OU generator. This is the first time I see TK in a video that is obviously tricked. Not good. Shit now what will we see next?
wattsup
PS: Sorry to be off topic.
27Bubba
@wattsup
After reviewing this it is possible that you may be right. Up close, it does look like the bearing pillow is welded (look around the bolt head it appears it crinkled. Machined surfaces should be better looking that this unless it was done in the butcher shop.
ZathEros
Quote from: verpies on February 26, 2012, 07:48:20 AM
What is the practical range limit of those long range wifi repeater stations?  Interisland?
~40 miles line of sight with use of re-purposed dumpster dive dish network antennas. (FROM MOUNTAINTOP TO HORIZON)
~11 Miles on flat ground with towers & dishes.
~2-3 miles on flat ground with just dishes.
