0 Members and 73 Guests are viewing this topic.
wattsup
@all
Just to terminate the exposure of the TK dual-flywheel motor-gen and to confirm that what I have indicated previously is next to 100% correct, just go back to the video and listen at 00:24 or 24 seconds into the video when he turns on the machine with his small 9vdc battery, listen to the sound when the drive motor is starting to turn. That is almost exactly the sound of a grinder motor. If the shaft coil was the sole motive force, then it would never have made so much noise since it is directly coupled to a shaft rotor. Listen to all the inherent noises involved and you will soon realize the shown components cannot generate all that noise on their own. But listen to the noises with the above diagram in mind and you will quickly realize TK was hiding some things from those investors.
Now I am not saying it is a fake anymore because the hidden parts could have some OU potential given he is using leverage. Leverage, that I tried to explain to the Romero wheel guys. In TKs case, the flywheel diameter is much greater then the next biggest thing in the system and that is the diameter of the generator rotor. So the flywheel has much more leverage on its side then the generator rotor has on its side. It is that difference in leverage that provides the energy for the rotor to cut thought the drag created by the stator when outputting power. So I get what he is doing in this system and it does have some sound principles and his pulley diameter ratios are all consistently well thought out. I would say the generator rotor would be turning at not more then 600 rpm and that is why he chose such a large sized generator. Low RPM but maximum output.
The other metal box is obviously hiding a set of batteries either in series or parallel, going to a DC/AC inverter then to the drive motor via a 9vdc activated relay. I would almost confirm as AC going to the drive motor. In this manner he is creating a loop and by doing so, if it is not OU then the battery voltage drop will be very gradual but slow enough to convince an investor that he will make big bucks if he finances this venture and its miraculous shaft coil.
It is still, in my view, a rotten way to try and make a living.
wattsup
twinbeard
Quote from: scratchrobot on February 29, 2012, 08:46:05 AM
He tried so hard to show nothing!
The plastic box is full of junk and battery's like in green box, even I could light those builbs that way.
Like CosmoLV say, most people here are not ready for the THRUTH and believe in troll's  ;D
Take a screenshot from the clear box video, and show me where the batteries are.  I see some caps.
I see some boards that may have been purpose made, but more likely are recycled/modified, hence the
white leads soldered to various points on various boards.  I see a plasma arc reactor.  I see a special coil configuration that Wesley and friends can explain pretty well.
forest
he he and the answer is : get two trolls fight with each other and we are free from anything and happy accelerating on load .....
T-1000
In regards of acceleration.. :)
Some people do understand and use Lenz law motors for benefit - they LAG it behind cycle time:
http://www.youtube.com/watch?v=czXmazZ4obs - NASA Video Part 1 - Regenerative Acceleration Explanation - YouTube
http://www.youtube.com/watch?v=WXKO8r-3xrw - NASA Video Part 2 - Regenerative Acceleration Video - YouTube
http://www.youtube.com/watch?v=IQ9KLfusQPg - NASA Video Part 3 - Minimum No Load Speed - YouTube
Use same principle in resonant transformers and you will get maximum output with minimum input... :)
The second part of energy will be recycled back to the source.
P.S> If you see OU, in most cases you're on missing counting of all energy sources, including ones not provided by you directly from battery/mains.
