0 Members and 28 Guests are viewing this topic.
ronotte
@wattsup,
No, I havent seen it, could you please be so kind to giver me a link? THANKS
I've replicated almost all (except the last one) devices from friend stivep & group, but at least in my case, I've not been able to confirm OU. It is true that as always replication is not exactly the like...but as you can easily imagine similar. Last device inluding air-ionization a 50Hz modulation seems interesting. I've already built the long coil (time consuming task) and I'm now ordering the beam tetrode. Here is a problem as the EL500... has a max rating of 100V and the russian equivalet used by stivep is running at much higher voltage (>300V)....so I'm unsure if try to find the original in order to maintain the same plate / screen grid voltage.
In the mean time I've also experimented with push-pull kacher...interesting and I tried to pulse a bifilar Cu/Iron with 1KV pulses coming from the Caduceus/pickup coil: no particular effect observed up to 3KV pulses.
Roberto
T-1000
wattsup and ronotte, if you repeat our experiments, just drop pm to me with your skype names, so I might help on devices tuning.
wattsup
@ronotte
There is a member named @Kaduci that posted this on this thread almost a week ago;
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg314044/#msg314044
Here is the youtube video of the guy with an ECD.
http://www.youtube.com/watch?v=FVMpoRhZLnA
Here is the Russian forum reference.
http://realstrannik.ru/forum/29-tpu/267-tpu.html
I just got myself two new 12vdc/12AH batteries and a small 1 amp battery charger so I will not blow them like I just did the last one three using my car battery charger and leaving it on too long. Also, just notice one bad thing about  using batteries. When I turn on the system at lower frequency pulsing, no problem but when I brought the pulses up to the 1mHz range, the battery negative wire just melted as if I made a direct shot. I think I will definitely need a fuse link and many fuses for these next round of tests. lol
Below is a photo of my set-up with new HV diodes (big), new spark gap, new HV capacitor(s). I have extra diodes and caps just in case.
@T-1000
Thanks for the offer. I will look to set-up a Skype camera and account. I think I have an account already but I never used it. I want to get a better set-up going before I start bothering you because of our time zone differences. Once it is up I will advise on the forum.
wattsup
ronotte
@wattsup,
Thanks for the full info. I do appreciate it :)  as TPU is still on my mind. Nice setup I do hope you able to see soon some effects.
@T-1000
I've sent you my skype info. Unfortunately I have had trouble with my adsl line so only now I'm up again. Plase contact me.
Roberto
ronotte
@wattsup,
as incredible as it is in the russian  http://realstrannik.ru/forum/29-tpu/267-tpu.html are discovering my own TPU driver electronics done I believe in 2007, other reference are also about various ECD replications of ECD by myself and Otto.
Roberto/ronotte
