0 Members and 128 Guests are viewing this topic.
Flux It
Quote from: wattsup on March 05, 2012, 10:05:37 AM
No, there was no electric arc. The heat transferred from the flyback bracket to the table top as you can see there are two places where you can see the bracket holes transferred to the table and the table top material has bulged a little upwards caused by extreme heat transfer. The crazy thing is the flyback is still working fine.
wattsup
Well I see electric arc in the burn, and if the metal was hot the burn would be under it, not around it and the bracket marks would be opposite direction.
wattsup
@Flux It
I know how you can confuse this because I should have taken the next image to show you exactly where the flyback base was on the table. In the photo below you see the bracket is slightly moved to the right of the table burn to show you where those two outcrops align with the burn when the bracket was directly over it. If you are referring to the white streaks in the burn mark, those are created by the table top material being bulged upwards from the heat and hence cracking at those points. Actually I now remember hearing a pop sound at one point and that is when I turned off the device the see where this burn smell was coming from.
@All
I just uploaded a small YT video of my current set-up now using my chopper circuit from @verpies. The thing runs well but no light bulb lighting. I then (stupidly yes but I wanted to show you guys the effect) showed that when I remove the capacitor that goes across the two primary circuit outputs, the bulb went on but the damn flyback started sparking in the un-used secondary section. So I had to stop it. This shows that under a very erratic condition, the bulb via the Caduceus Coil is lighting up.
I still have to try out more primary coil configurations as I have 2 first layers and 2 second layers to play around with. i am sure one of these configs will be much much better then the others so time will tell.
http://www.youtube.com/watch?v=u7NlK5F4O7c
wattsup
PS: Now to download Skype. Seems I flushed it some time ago.
27Bubba
@wattsup
I like you setup.
Sorry can't help with the capacitor, don't know enough about it. But, can you tell me how big the capacitor is that you are using? . I'm currently working on similar setup as yours.. I noticed you have an oscilloscope connected to your circuit. Can you shed a little light how it is connected. Do you use X100 probe and where it is connected?
Thanks.
Good luck.
Stay safe, don't burn any more tables.. ;)
Kator01
Hello Wattsaup,
now look at these transformer-types:
http://www.youtube.com/watch?v=0bWDs-pedl4&feature=related
I discovered the video after I finished watching yours.
Kator01
