0 Members and 128 Guests are viewing this topic.
Jack Noskills
Does this mean Tariel does not have a partner anymore ? Does anyone have more information about current situation, Wesley ?
LTseung mentioned he has partner that is willing to co-operate with that African solution of a free energy device, there is a thread about it here. That is inferior to Tariel's stuff, rotating motor, 5 kw, costs 6 kEur and so on. A rip off. This partner is from China I believe and he is putting up plans to make this African device in large scale. I wonder if it would be worth while to connect LTseung with Tariel ?
Another thing that comes to mind for Tariel to use is the prize route. Licencing is difficult since there is no patent granted. TK's patent claim was rejected because 'Bedini has already patented free energy'. Don't know if new patent application is in progress.
Turkish company was forced to change their name and their business. Changing company's name is expensive stuff, all material that has companys name needs to changed.
Damn, I wish Tariel himself would join in this discussion, even if indirectly through someone. Wesley, you said you have him on skype, time to convey some new ideas to him ?
ronotte
@T-1000,
Hi, I'm working on circuit attached. I hope you may help.
1 - I've doubts about coils connections, would you be so kind to detail all connections to coils-set (L27, L28, L30, L31 and L32)?
2 - Tr1 220V floating secondary (upper side) appears connected to L31 low-side and in turn to Br1 positive output (315DCV): is that correct? Anyway this connection is dangerous because Tr1 output is floating...but in this way becomes referenced to 220V 50Hz home rail. Summarizing why use the double transformer approach (Tr1, Tr2) to have a floating 220VAC and then re-reference all to input rail via bridge Br1?
3 - Tr1 220V appears impressed directly to Lamp La2: this means that anyway La2 lights...even if for only the available power (about 20W  ..Tr1 rating)
4 - In russian site, there is a new indication for this circuits. It reports: L31=1000t and L30= 4000t (It is far from 350 -1100 like in attached pic). Is that to be considered final?
Thanks
Roberto
cosmoLV
Quote from: hartiberlin on March 06, 2012, 09:20:58 PM
Hmm,
do you mean
http://www.eraslan.com.tr
Were these 100 KWatts Kapanadze units tested at their location ?
Many thanks.
Regards, Stefan.
Yes, this is this!
By the way, Tariel now is in Germany as friends say he work with company E-ON http://www.eon.com
But this fact is not confirmed jet
Keep your chakras opened :)
T-1000
The +315v source comes from missing  transformer with step up coil and same primary pins from 220v source in parallel.
The secondary turns ratio is 1:4 and cw+ccw windings. You can use 1000:4000
The primary depends on vacuum pentode with quarter wave length resonant frequency of 4000 turns coil.
The Tr1+Tr2 are 50Hz source for frequency mixing.
Kator01
Quote from: cosmoLV on March 07, 2012, 02:12:28 PM
Yes, this is this!
I hope that this is not true as you can read here:
http://www.buch-der-synergie.de/c_neu_html/c_06_12_wasser_dampf.htm
E.ON Venture Partners GmbH  took over and corrupted the Enginion AG, a company which built a efficient steam-motor , model ZEE 03 which was successfully tested and built in a Volkswagen Buggy in 2002.
So any person here who is in contact with Tariel should give him a warning
Kator01
