T-1000
In regarrds of device tuning N. Tesla had only voltmeter and ampermeter for his stuff..
Everything he had to calculate was wire length and diameter what corresponded resonant frequency 1/4 wave length and that's all :)
So if you know what makes device to work, no expensive equipment is required...
ronotte
@wattsup,
thanks very much for having done a very useful clarifying job on TBC issue :) . I'm desperately try to find the TBC110na...but at least for the moment no luck. I'm  asking to STAAAR group if any possibility to have  an indication.
Thanks
Roberto
frantz
Quote from: cosmoLV on March 08, 2012, 09:12:42 PM
Yes.
There is no mixing of frequencies.
Most important thing is to generate sharp pulses (triggered) the pulse from Tesla coil need to be sharp "This may be good example: electric gas igniter"! This is the only source who generate impulses. this is the only generator there! No mixing and no modulations.
Second is bifilar coil closed looped by itself â€" when impulses are generated to inductor it magnetises a bifilar coil (it creates a magnetic field in bifilar coil) so in total you have one source "generating pulses" but in fact you have resonant magnetic generator with two fields (similar to Hertz Resonator - "see picture under post")
"electrostatic: from inductor and Tesla coil
& electromagnetic: from bifilar coil"
(i just explain in parts, i do not want to go in deep details. But i hope you will think and try to understand arrangement of the setup)
I can not to agree with this theory.
No mixing frequencies: TC have a some frequency of "sharp pulses"
Bifilar: if it is a resonator, should to have some frequency of work (resonant frequency)
If these two points will not work together in synchronization mode, we will receive nothing....
"bifilar coil closed looped by itself" - the resonant frequency of coil which have few micro Henries and one or two pF (self capacitance) is looped itself without capacitor is to high to using this solution (MHz to GHz).
And main question is : what about third coil?[/size]
regards
andrea76
Quote from: Farmhand on March 11, 2012, 07:01:00 PM
Actually I think at 12:59 he sticks his knuckles in the cooling fan, not a shock.
The thing I am suspicious about is the green box, the battery powers the converter
the converter is connected to the the green box and the green box powers the resonant coil
setup which powers the lights. The inverter is connected to the green box for much longer than
the green box powers anything. And the green box looks heavy. I'll play devils advocate for a while.
The devils advocate says the green box has a bunch of Nicad or NiMH batteries connected to make
a 220 volt battery which is recharged by the rectified inverter output, the transistors chop
the 220 DC at HF for the resonant coils, the heating transistors ensure the green box batteries
don't get too drained because they only run it for a short time before they shut it off, claiming
heated transistors as the reason. When he connects the charging feedback it's not for long.
In reality if it is running from free energy from the environment he should be able to recharge
a bank of batteries rather than light some lights. That is in no way a convincing demonstration
they repeatedly turn the device off it only runs for very short periods.
Other things that don't add up are, he says that he wants patents, but then he says it is Tesla's
invention. So he can't get a patent anyway. Then he tells the guy at the end that the Earth connection
can be replaced by a circuit. Also at the end the video is pointed at a 5 kW generator for quite a while.
Devils advocate says the setup is powered by a 220 volt battery in the green box which is
charged repeatedly by the inverter/converter and the car battery, the setup can't hardly even run
long enough to boil a kettle. At 16:30 he shuts it off and says the transistors are heated then one of them
holds his thumb on the transistors for quite a while without getting burned just after they turned it off.
I'm not convinced, but that doesn't mean much. When there is a box big enough to hold batteries
I am immediately suspicious, the aluminium box the newer motor generator is mounted on could hold
a lot of vehicle batteries as well.
Cheers
If you look closely can see one spark from knuckles to fan........
cheappower2012
@T-1000
Tuning with only meters is possible although I'm not convinced that
this is an ordinary Tesla setup
and that Tariel isn't lying to protect hes invention.
To every body: here's a few pictures that show on the 2004 device video,
that it has a high current transformer,it has copper braids
there used only on low voltage high current transformers.The rectifiers are
high current types,it appears that all the cathodes are common
the anodes are connected in pairs by copper braids,and appear to go to the coffee can object.
On one picture there are two objects, black, odd shape sealed with two wires,could be inductor,capacitor,resistor or?
This could be a Russian or European made part,anyone seen this part before,what is it?
