0 Members and 966 Guests are viewing this topic.
xenomorphlabs
Quote from: baroutologos on March 29, 2010, 06:56:09 PM
So now the potential replication has low pass filer or inverter for conversion? What i see from the video is that the load is directly connected to a coil that at least is inductively coupled (if not conductively) to a spark gap directly. Spark gaps create vahoc of high frequencies as is known.
Same with Kapanadze. The geo.avi shows the lamps directly connected to an output few thick turns coil without any smoothing cap or filter or inverter and is measured like normal 50Hz electricity with normal DMM. (even though it shows minor rf signal)
I do not know what you are saying but for me its quite suspicious that behaviour. At least to the replication
Salutes
Just don´t want you to misinterpret something.
I just speculated about the low pass filter. The Kapanadze patent
schematics DO contain filters, but these patents must be for more advanced (smaller) devices like in the glamour presentation.
So something must be considered necessary to be filtered by him.
I don´t think any of the replicators has used lp-filters.
It is very hard to say for sure how the coils are really connected to the green box, there is dozens of interpretations floating out there about where
the wires are connected to, because there is no clear camera shot that shows the space between the coils and the box.
So i consider everything speculation concerning the wiring interpretation.
I agree with you on the DMM behaviour at high frequencies
and at some points in the outdoor presentation you see the meters
behaving erratic.
baroutologos
I also read the posts of the Russian Admin. He says that is possible get 50hz output from those device, yet rates Teofilus video as a joke... go figure.. :)
Assuming he speaks the truth, I ask. What kind of Transistors could be used for the 5Kw akapanadze device (NPN-PNP) or even for the 100Kw device?
The larger i know are some hunderd watts at best.
grizli
Quote from: baroutologos on March 29, 2010, 07:49:21 PM
whats the purpose of transistors ? i didnt get that ?
Omnibus
xenomorphlabs
He could use transistors like BUL742C or similar.
2 of them would fit the bill for a speculated voltage of 2kV.
The spark gap is adjusted very narrowly, so 2kV could be the used voltage.
A possible transistor application can be seen in comrade Victor Grieg´s circuit suggestions (see attachment).
