0 Members and 534 Guests are viewing this topic.
rensseak
Quote from: FreeEnergyInfo on March 12, 2012, 04:14:55 PM
FREE ENERGY VIDEO ??? ? ....
www.youtube.com/my_videos_edit?ns=1&video_id=cLQqvnLS7qE
I made this video to show a possible arrangement of the coils and magnets for the romeroUK device. I do not know if it would work. It was just an idea because of the counterrotating effect.
Osiakosia
Quote from: wattsup on March 12, 2012, 05:05:18 PM
Q 1   And for me. lolololol
Q2 I am wondering about one question if you can take a picture of the side showing wires on pins 4-5-6-7. According to the specs, it says the 4-5 is 0.41mm and all others are 0.23mm. Can you see in your flyback if this shows thicker wire for 4-5 as if it is correct, then I will want to replicate that as well.
Q3   4-5 = 80 turns @ 0.41mm or 25.5 AWG (This is good to have a thicker wire on the COC center tap side.)
       5-6 = 80 turns @ 0.23mm or 31.0 AWG
        6-7 = 150 turns @ 0.23mm or 31.0 AWG
        7-8 = 610 turns @ 0.23mm or 31.0 AWG
        8-9 = 190 turns @ 0.23mm or 31.0 AWG
wattsup
Dear wattsup ,
Here I sent to you photos of the wires .
Q1- If  I will have more then one 110LA I can sent it to you . Hope it will be .  ;) But with one
provision . You will sent one of yours TBC WATTSUP LA  to me after production process . ;D
Q2- Photos at the end of message .
Q3 - In one of books of radioelectronis from 1972 i finded the table about TBC110LA windings .
My guess is perfect . :-[  . 150 turns pin6-pin7 . But others windings is little bit different  ???  .
Best regards
ronotte
Hi all,
I'm very happy to see how synergy is working :) I have to thank all that are contributing to understand & solve the TBC issue.
Including quarter wave resonation effect directly inside the TBC itself sounds great...on the other hand do not forget that brovin's kacher, Tesla coil magnifier and last WNYg 'Ionization device' do make use of the same principle well understood by current knowledge.
Anyway, my personal opinion, based on many implementations of TC coils, kachers, etc,  is that said  fact alone is insufficient to provide any OU but should be considered an helping factor.
@wattsup,
wow, I see that we are now finally  having all the necessary info to eventually build a kind of enhanced TBC useful for our purposes. As it seems impossible to find such units on the market, I strongly suggest you to try convince your friend to build a prototype similar to TBC110nA hence incorporating all the necessary windings with secondaries length according to quarter wave proportion and resonation possibility with external cap. I think do not be the only one who could buy at least 2 or 3 of that units. It is clear that designing such unit is not easy but I think that all interested could suggest useful hints.
Note: During weekend I've tried to contact you on Skype but proven impossible. I have sent you a contact request (you can see it on the main contact list window): you should accept it in order to allow a contact.
Roberto
wattsup
Quote from: Osiakosia on March 13, 2012, 06:05:21 AM
Dear wattsup ,
Best regards
@Osiakosia
Wow, now this is what I call International Collaboration, all guys pitching in to get things cleared up for everyone else. No problem, I can ask the manufacturer to make one more when I am totally ready.
The specs you are showing of the TBC are different then the ones I put up. I think your specs are of the Lithuanian model and my specs must be from the Russian model.
In your spec, the differences may not sound like much but they are substantial. First of all the HV is using 0.17mm wire of 1100 turns compared to 1200 turns of 0.10mm. This is almost double the HV wire diameter and this was one of my main concerns when asking to manufacturer was to ask them to make that wire thicker to be more durable. Now I have the answer. Fantastic.
Also, the 4-5 is 0.41 like the other, but the 5-6 and 6-7 are 0.29 so a little thicker and then the 7-8 has less wind but same 0.23 and the 8-9 is also the same 0.23. The less winds in 7-8 is probably because the original 610 turns may have produced more internal heat. The beautiful thing is when the HV- (0.17mm) goes to 9-8-7 at 0.23mm, then 7-6-5 at 0.29mm then 5-4 at 0.41mm, so the wire is gradually increasing in diameter which is a logical strategy to prevent chances of internal wire fusing/shorting. All in all a much better design. Thank you thank you.
Now all I need is for @T-1000 to hopefully expand on his last post and I will be 100% ready to provide them with the build specs.
The most puzzling thing about finding out more info on the TBC is the fact that obviously the Russian and Lithuanian models are sufficiently different to warrant different models numbers but they decided to keep the same model number. Hmmmmmm. They probably thought it would be less confusing for them in that day to have the new models as the obvious replacement of the older model and by not changing the model number, they would not have to explain why they made the changes. Maybe the Russian model (if it was the first one) had internal shorting issues that they did not want to openly admit and just made the changes quietly to not stir up warranty requests. Don't know for sure but I am sure they did not count on anyone using them 40 years later. lol
wattsup
