0 Members and 79 Guests are viewing this topic.
Osiakosia
Quote from: IWD on March 25, 2012, 12:44:48 PM
Hi Osiakosia, pls, can you measure the inductance of windings? and post it.  I am unable to find it
Dear IWD ,
Excuse me for delayed answer . Only today I bought new LCR meter for inductance measurements .
Mastech MS5300 . So please find details for TBC110 LA .
nickfishick
Quote from: cosmoLV on February 03, 2012, 10:17:24 PM
Just finished making a pcb layout for quality 50Hz or 60Hz modified sinewave AC generator for inverter
it is based on one PIC programmable memory chip...
i attach images and PDF of PCB layout â€" who want's can make it!
Two things:
1.) you need to programm PIC with pic programmer
2.) Center taped transformer 10v - 0 - 10v output 220v or 110v
/ just forgot, i not label the mosfets STP55NF06L These are special logic power mosfets that require just 5v to switch on fully.
They also have a very low   0.014Ω Source to Drain resistance when on, which means they can switch high currents without wasting power as heat!/
A. This is PCB for etching: http://failiem.lv/down.php?i=mwqeoom&n=Inverter_PCB.pdf
B. HEX code for 50Hz and HEX for 60Hz: http://failiem.lv/down.php?i=hpnulzg&n=50-60_Hz_HEX.zip
hi,
yesterday i have make your inverter and work perfect :)
i wonder if you help me to modify your project to work with toroidal mini transformer (that have 28 khz - 38 khz / not 50 hz)
what i want to do:
-i have an inverter with sg 3525 and irf 540 with toroidal transformer tha give me at out: 220v/28 khz.
-i want to use your pic and hex with an ir 2110 driver to drive irf 840 and achieve the 220v / 50hz at out. It will be possible that? I need help because i don-t know how to work with ir 2110 and other.
Can you help me please?
thanks
Jury1
FreeEnergyInfo
