0 Members and 96 Guests are viewing this topic.
jbignes5
Quote from: leo48 on April 04, 2012, 03:51:51 PM
I was not able to shield the radiant energy as Tesla called it in any way through anything.
The 'only way is to position itself away.
Leo48
Thats not true. Thats why Tesla loved aluminum so much. It reacted in a very different way then normal means. It is all the strange things with higher frequencies and aluminum keep happening. Isn't it strange that led diodes and most transistors are made with aluminum as well... Look at the strange results of electrolytic caps show. They always told me it was a battery like effect but to tell you the truth after I dissected a few caps that I have used in these experiments not one was damaged galvanic wise. No electrolysis marks at all... It was the aluminum itself.
Listen the best way to insulate the coils is to fill them with oil. Then you can push them much further. The problem is you got to boil them to get out all the air in between the windings. Once done they will go way beyond thier manufactured tolerances.
jbignes5
Quote from: jbignes5 on April 04, 2012, 07:24:23 PM
Man I keep missing the edit by minutes..
Again for your reference:  http://www.tfcbooks.com/tesla/1892-02-03.htm
Figure 12 shows what the aluminum was for and how it shielded the wire from interacting with the bulb's gases or vacuum.
wattsup
Quote from: T-1000 on April 04, 2012, 01:12:50 PM
"I have been posting updates to my web site at http://alt-nrg.org/Kapanadze.html  Beside the smaller yoke ferrite shown there I also have created a new one about twice the size that I have been experimenting with. When I energized this coil from a spark gap, the magnetic interference created was so intense it shut down all of my USB webcams, caused my computer to freeze, even prevented my daughter from streaming music to her laptop 50 meters away at the other end of our house! My neighbors have not said if they experienced any problems and I have no intention of asking them! LOL!!!"
So, unless you got right equipment for this experiment, it is better to stay safe..
Cheers!
This has been my problem since the start with the yoke and the Caduceus Coil. But I think the interferences are also due to the flyback as much as the yoke or CC. In old TVs this type of flyback is often placed in a metal shield casing while the yoke is open air hanging on the cathode tube
After a pulsing session, it is now second nature for me to first disconnect and reconnect my keyboard and close the TV and other instruments. I also have to check a wall mounted digital thermostat that controls the basement heating elements because the pulsing effects have gone right up to there changing the temperature setting. The flyback also blew one of my 50MHz FGs and two of my power supplies and a volt meter and endless mosfets. I think flybacks are like Bronco's. Be careful when you ride it and always respect the HV.
This is serious shit. Most of the critics that only do what @otto called "PC Heroes" have no idea what kind of crap this is to work with. HV shocks as well as pulses going into the body. Sometimes at certain frequencies I could feel something twitching around in my leg or elsewhere. Common knowledge is that a man of 180 pounds has a good 2.5 to 3 pounds of parasites in the body. Maybe some of these frequencies are pissing them off. Who knows.
I am now using a full rectified with four huge diodes and four HV caps. I took off my Caduceus Coil and am trying to do a direct Tesla Ozone Patent Set-Up. Since during the many rounds of testing in the past I have blown a good number of bench equipment, I need to make a new primary drive control circuit. I am wondering if a magamp type set-up would be good just to drive the flyback primary. Seems to me the only way to drive the primary is via a secondary of another coil. That other coil could also have another second secondary to output the flyback from the flyback without trying to use diverting transistors. You cant just direct drive a flyback. If you are working with variable frequency generator, you will hit one frequency too many and bang, the equipment is zapped.
So as I am now inclined to realize that you cannot just put your drive directly to the flyback primary. Yes many are getting away with this type of usage but their circuits are fixed frequency drive method so the actual fixed frequency used can produce output but also would be miles away from the major effects you need to push this to the next level. So what is really required is a variable frequency system where the initial pulse is going through various steps to reach the flyback primary in a way that when the primary starts to spit out its deadly flyback, it cannot kill the pulse or the feed power source. This is where I am at right now. I think the use of some pre stage toroidal cores will do it. I will investigate this during this weekend and report back.
wattsup
jbignes5
Yes the magamp would be perfect for what you are talking about Wattsup. I highly doubt you will have issues with feed back with the magamp. There are several ways to use it and even with feedback of it's own. You might want to oil bath it as well to increase the ability to handle the extreme feedback associated with flybacks like that.
Osiakosia
Quote from: verpies on April 04, 2012, 05:39:24 PM
The chemical composition of the ferrite core most likely is critical in this device in addition to its size and shape.
Thus it is prudent to replicate it with identical components.
Osiakosia has a ferrite from the russian Rubin TV exacly like the one used in the working Yoke device.  Maybe he would lend it to you...
As far as the deleterious effects of the device it is not anything that some distance will not cure.
@wattsup
The Yoke device had two modes of operation. The low-power mode does not subject the core to HV.
If the core indeed has changing properties (still to be confirmed) then a frequency-agile driving scheme will solve this difficulty.
Dear Wattsup ,
At present time I am searching for any information regarding russian ferites for deflection systems .
Unfortunately it is wery poor .
Now I am waiting for the book about ferites from Russia .
I need help for signal amplifier to drive U-shape core .  I have build one using STK 392-40
but it work only till 200 kHz . ( It have 3 channel but are usefull only to drive 15 turn coil ) .
Will be very thankfull for any help .
Osiakosia
