0 Members and 200 Guests are viewing this topic.
cHenriques
I don't understand the Forest's schematic, I'm waiting for his reply
to me and based on my experiments this function like this:
where the earth is a good water pipe on the ground, and the antenna can be a elevated ball
I think also that the HV coil can be connected to the ball and the capacitor to the ground
regards,
Henriques
27Bubba
Thanks Henriques and T-1000 for replays. As T-1000 suggested in his reply I did connect the HV negative to the earth and the smaller coil to the earth as well. The problem is now the spark disappeared, I can hear hissing sound, so my coil have short somewhere the small light bulb barely glows it can be seen in dark only. I guess, is "back to drawing board" for me.  ;)
Best..
woopy
Hi all
As this topic seems to open wider and wider, (with atmost interesting proposals )
i submit here one experiment of coupling between a Kacher and a steel wire loop.
Hope this does not disturb
Good luck at all :)
Laurent
http://youtu.be/gdVL546GoZA
slapper
Thanks for the video woopy.
Did/do you get different results replacing the soft steel loop with a similar solid copper wire loop?
Take care.
nap
we are not alone :)
forest
Quote from: cHenriques on April 12, 2012, 02:46:25 PM
regards,
Henriques
If ball cannot catch radiant energy (not elevated, no sources around ) then you are correct - connect HV near ball or modify like in schematic.
HV ground is separate from real ground, real ground must be controlled like in electrostatic induction video and finally Avramenko or diode bridge is not the best scenario. Can't help more,trying to recover from bad flu...
