0 Members and 197 Guests are viewing this topic.
T-1000
Quote from: frantz on April 13, 2012, 03:24:43 PM
Just watch.... (in Russian language) but .... if you don't understand ask your friend whos know Russian.
And just think.... ;-) not so strong
Hi Ftantz,
Thanks for the video links.
Just even I speak fluent Russian language, still there are unknowns about  input power in those experiments as ampermeter did not show it properly.. 12W/6W bulbs can be easily lighted from 2 generators. I understand the lack of knowledge there but still, 1 Ohm resistor in series + oscilloscope shots would allow to see a lot more what is happening there.
cHenriques
Quote from: 27Bubba on April 13, 2012, 02:42:12 PM
@jbignes5
Thanks for the reply. I did read about the ionizers here(  http://en.wikipedia.org/wiki/Air_ioniser) before you posted the web address. But I still don't know what kind of ionizer cHenriques is using in his setup.  You said "Ionisers use electrostatically charged plates to produce positively or negatively charged gas ions that particulate matter sticks to (in an effect similar to static electricity)."
OK, so what is it?  Is it a tube, a diy gizmo? I have spend lots of time google'ing this with out a satisfactory result..
Best..
hi 27Bubba,
Is not necessary a ionizer, the aim is to block the charge to go to the ground, so if you put a simple little capacitor on the end of the HV coil the massive charge of the bank capacitor don´t goes to the ground
other problem is important, if you discharge the tank capacitor through a tesla coil primary, it forms a ressonant circuit, so when the polarity of the bank capacitor to be reverse will exist a shunt created by the diodes :S maybe a valve regulador can help us, see this http://www.nuenergy.org/alt/working_energy_device.htm
27Bubba
@cHenriques
Thank you very much for the explanation. Now I understand why I no longer have a spark even thou I hear hissing sound. The capacitor I'm using is way to big. Thanks again.
Cheers..
BR
cHenriques
Bubla,
What is the schematic that are you using right now?
