0 Members and 129 Guests are viewing this topic.
Сергей В.
Hello wattsup
You don't need to use SOT8 IC's to demage your eyes soldering!!
Try this. Very speed switch circuits. You can split SWITCH-4 to 3 part but main ground must solder on one point closest to sources transistors. Don't use optocouplers they are terrible slow. Use isolated transformer if you want izolation !!
Instead 2Т3115-2 use mm band Transisor. Ft>10 GHZ..50GHZ
For power use car battery 12V 50-150 Ah !!
Ganzha
Quote from: woopy on April 24, 2012, 04:55:36 PM
Hi Wattsup
Thanks for your interest, and be sure that i am following your progress with great interest.
Perhaps this video can be of interst here
http://youtu.be/TjdaSqSIbqw
good luck at all
laurent
Hi Woppy! Glad to meet you!
I had analised your last experiment and I have got a schematic ot that
look here
wattsup
@all
Thanks guys for your suggestions but for now I want to get the opto circuit of @ronotte done.
@ronotte
I am about finished making the opto circuit but need to make sure of something.
In your opto circuit above, on the IRF7307, are pins 7 and 8 together and also pins 5 and 6. Looks like it on the diagram but unlike 1-3 and 2-4 that are clearly shown as connected together, the others are not as clear. lol
Thanks for being so patient with me.
wattsup
ADDED:
I looked again at the pdf and see that these are internally connected. So I guess I can use one or both and it won't make any difference.
ronotte
Hi wattsup,
pin 7,8 and pin 5,6 are internally connected indeed. So you could use only one pin in each couple...but is common use in order to increase max peak current to use both pins shorted externally together. Generally as good practice I short externally pins 5,6 and 7,8.
About speed I've found that the mentioned opto coupler's 100MHz bandwidth (about 10nsec rise time) is more than sufficient for our purposes. It goes without saying that I've also successfully built in the first attempt for Spherics 3D-TPU a pulse transformer driver...showing much similar efficiency/speed (full PSPICE sim available).
Have fun
Roberto
